Where on the ES350 rattling occurs most ?
I padded all my 4 doors since it does rattle and unplug my oem woofer for an aftermarket sealed one in the trunk. But i wonder where else that ratting can occur in the ES350: rear deck, glove compartment. I notice that on the highway when i hit bumps, there a buzzing sound coming from the back, wonder that it could be ?
Any experiences ?
Any experiences ?
thank you for the reply, i will test the car out for rattling soon with some rubber mallet and a friend in the back. Yes, the sunroof does rattle, mostly when i close the door. Rear windshield ?? odd since it is fixed, could it be more the power sunshade....
Aside the buzzing sound i've described, the car is quite rattles free.
Any experiences ?
Any experiences ?
I also have a slight rattle over bumps that seems to come from the driver's side B pillar. Probably from the seatbelt components inside.
Yes, i have the rear sunshade, I've tried putting the sunshade up and down, no luck. The buzzing rattling is not occuring at all speed ??? in high speed. Interesting about the B pillars, i can open it up to see and pad the area for good . Also, i don't think it is coming from the trunk also since it is vividely audible from the cabin.
SickES350, you are right about that, but i have to mention that i listen to classical musics so i can hear every bit of noise in the cabin
Depends on the road surface and the frequency of the vibration going thru the car and what is in tune with that vibration frequency to give a rattle. On these Texas roads there are some that have some sort of surface that cause the plastic around the inside door handles to rattle. Experienced this on the way home tonight.
And I had a dash rattle in cold weather that was fixed under TSB.
For the doors rattling, there is a quite fix, just pad the metal bracket on the arm rest.
Actually, the car is quite quiet aside the above point, that is why i want to focus on it.
