K&N oil filter for Es350
Well you can get the filters from like walmart or autozone and do it yourself. That is what I have done. The associates and machine they have there can tell you the serial number for the car. Royal purple may be a bit much for our car but havnt yet to try it.
got royal purple running in my car. 2kmiles... runs like its on oil... cant say much about it... oil is oil... is oil..... if you can honestly feel the difference in performance in everyday daily driving (without dyno) with different oils... you should get your car checked out.
Gekae....any reputable place that mainly just does the standard oil chgs, transmission fluids, etc should work. they are good at getting it done quickly and getting to next one. sure in Ca. you should have some options...chains we have here....jiffy lube, kwik kar do an excellent job...can have it done for about 35.00 oil chg..oli filter top off other fluids, etc. by computer they are able to pull up exact car's specs to make sure they put what owners manual reccommends
Toyota dealer is good place for oil change, the last oil change for my ES350 I did it myself without raising the car, the filter was from walmart (2007+ Camry V6) and I had get the special oil filter tool to open the cartiridge.
My garage left that special oil filter tool attached to my oil filter when they changed it. It fell off somewhere who knows. They bought another one and painted bright yellow.
lilbluu
06-01-10 03:44 AM
ToyotaLexus
Maintenance
02-17-09 01:28 PM
