ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
ES350 Wheel Questions
Old 09-04-06, 07:08 AM
leolynn
leolynn's Avatar
Default ES350 Wheel Questions
I just ordered my new ES 350 and would like to put larger wheels on it but keep the soft ride. What would you suggest for wheel and tire size and will this cause any problems with warranty or the electronics?
Old 09-04-06, 07:37 AM
Tammy
Tammy's Avatar
Of course, this is up for debate,
My thinking is that if you decrease the sidewall of the tires by increasing the wheel size, and with the change, higher tire pressures, the overall ride and handling will be affected negatively. Tire sidewalls flex as a function of the suspension, making for a smoother ride.
Any change effects the other components of the suspension. My suggestion is to purchase the ES, drive it and then consider wheels when the original tires are worn out.
As long as the tire circumference remains the same, the electronics should not be affected, aside from the tire pressure maintenance system. The air valves need to fit the new wheels.
Old 09-04-06, 07:41 AM
ES350Bob
ES350Bob's Avatar
I'd take note of the width currently on the vehicle and would be reluctant to increase tire width as the inward taper of the body frame allows dirt/mud to be thrown up on exterior as it is, any wider and you'll compound that problem. Especially noticeable in rear wheel area.
The wheel well area for me is as bad a design as the wipers scratching the paint along the back edge of the hood when lifting them for cleaning if you are not extremely cautious when first ever doing it.
rustytank
Hybrid Technology
39
03-28-19 10:29 AM
Brockton
Wheels, Tires & Brakes Forum
12-10-12 08:07 PM
designo
19
10-01-10 04:05 PM
intrmsof2
03-31-06 08:08 PM
jbee
02-23-05 08:29 AM
Quick Reply: ES350 Wheel Questions
