Rattling from front driver's side
My friend's 1998 ES300 has a knock coming from the front driver's side strut area. I'm not exactly sure if it's the strut.
What happened is, we had all four struts replaced with new ones. After it was done, we started hearing the rattling. We would get a rattling that sounds like there is a loose socket (the tool) that someone left up there, and every time we hit a bump or go over rough roads, we can hear it rattling. It's a sharp rattling sound.
We later took it back, and they replaced the shock just in case the new shock was bad. It still rattles. Her CV joint boot was leaking, so they replaced that also. It still rattles. The shop also torqued every nut to make sure it wasn't something loose. It still rattles.
We took it to Lexus and they confirmed the sound. They found the upper engine mount to be bad, her front brakes were bad, and they also said the right front strut was bad. The thing is, the rattling comes from the driver's side, but they said it was the right front strut (is the right side the passenger's side). Also, the upper engine mount is on the passenger side.
I will replace the brakes tomorrow, and call to talk to the technician at Lexus. Does anybody have any ideas?
Re: Rattling from front driver's side
A couple days ago, while I was replacing the front brake pads, I noticed the outer tie rod end was leaking grease. I replaced it, drove it, and had the same rattle. Then the next day until now (3 days), the sound is gone. If it comes back, I'll check the door articulation like you mentioned.
over40driv
Suspension and Brakes
12-01-12 07:48 PM
mruff
01-31-11 01:22 PM
bibbens
01-16-03 04:46 PM
