Bad Rack & Pinion?
Bad Rack & Pinion?
Whenever I make a wide left turn my steering wheel gets stuck momentarily and i hear a snap as if something was holding it back. I've been told this may be my rack and pinion, but is there a less costly solution, since its only on left turns? I just had both axles changed so I'm tryin to save $$.
Lexus Connoisseur
Yes the steering rack is a fairly expensive part rebuilt or especially brand new. Are you leaking p/s fluid? And when was the last time you checked the power steering fluid?
Is the alternator belt also connected to the P/S pump? If so, I just had it changed. My P/S fluid is fine it reads MAX. I want to explore all options before I change the steering rack.
Lexus Connoisseur
Lexus Connoisseur
I just changed both axles, so yes the cv boots are in tact.
