2000 ES300 Rear Wheel Bearing DIY Advice/Suggestions
I recently purchased Raybestos 712009A Professional Grade Wheel Hub and Bearing Assembly for my 00 ES300, and I was seeing if any of you had any DIY Advice/Suggestions-- the reason being because the emergency breaks and because I might have to mess with the ABS/speed sensor.
Thank you all.
Thank you all.
This is an easy swap, the hardest part will be removing the brake calipers so you can get the rotor off. After that just 4 bolts, don't forget to torque the bolts I think they are 60 lb/ft but not 100% on that. You don't have to remove any of the parking brake hardware or touch the ABS sensor.
brainsurge
04-02-18 02:26 PM
