94 es 300 Oxygen sensor wiring
i need info on the wiring colors on heated oxygen sensor bank 1 sensor 1. I have to check as I keep getting a code P0135 after replacing sensor.
edstofegajr
Yes I changed the right one, however I just tested the new sensor and it is bad. I swapped the front sensor to the back( by firewall) as this one is more difficult to work on and installed the bad one in front where I can easily replace it. I am sure that I will now get a new code P0150.
Thanks for the reply, I have received a lot of helpful info from this forum. I have read all the posts about oxygen sensors and have found a link for the factory service manual which I was following to troubleshoot this problem.
