2000 ES300 Brake/Rotor & Wheel Bearing Replacement
Old 05-11-15, 02:27 PM
dsigala
dsigala's Avatar
Default 2000 ES300 Brake/Rotor & Wheel Bearing Replacement
Anyone have any good advice, DIY instructions, details, schematics on doing a possible weekend job on the the brakes/rotor, and wheel bearings on 2000 ES300.
Thank you.
Old 05-11-15, 02:53 PM
BDSL
BDSL's Avatar
Front or rear? Rear is easy...
If front, more headache.
Old 05-11-15, 02:59 PM
dsigala
dsigala's Avatar
Front/back brakes/rotors(only if the rotors are bad) & back bearings.
Old 05-12-15, 05:36 AM
BDSL
BDSL's Avatar
Back bearing is easy.
Once you have the rotor removed, you can stick a socket with extension through "hub / knuckle...whatever you call thing". It is held down by 4 bolts or nuts.
Old 05-12-15, 07:21 PM
speedkar9
speedkar9's Avatar
My advice is to make sure you've got brake lube, a wire brush and enough brake cleaner before you start.
Here's how the front brakes are done:
Rear brakes:
And parking brakes, skip to 3:17 where I explain how the bearing would come off:
Old 05-21-15, 07:43 AM
mugencivic
mugencivic's Avatar
thanks for the vids, will need them when i change out my brakes and rotors in the near future
Fpan87
RX - 3rd Gen (2010-2015)
02-21-18 10:28 AM
MarksES300
08-10-17 01:20 PM
trhs75
RX - 1st Gen (1999-2003)
09-21-09 08:46 AM
rodeo360
GX - 1st Gen (2004-2009)
12-17-08 05:25 AM
hd54321
10-11-04 10:26 AM
Quick Reply: 2000 ES300 Brake/Rotor & Wheel Bearing Replacement
