bank 1 sensor 1 05 es330
CEL popped on and autozone scan said bank 1 sensor 1 O2 sensor. I searched the forum but couldn't find the part number. Is this the right sensor? http://www.partsgeek.com/cart/
Thanx
Gary
Thanx
Gary
For some reason the link I posted above is wrong. so these are universal?
http://www.partsgeek.com/catalog/200...io_sensor.html
would this be the correct sensor? is it the same one as above?
http://www.densoproducts.com/product.aspx?zpid=18831
Use a Denso sensor. Denso lists A/F sensor part # 234-9057 for your car. Amazon lists it for $109.45. Follow link provided by Lexus2000 to double check my findings.
Denso lists part #234-9042 for bank 2 sensor 1. When Denso says "upstream front" they meant bank 2 sensor 1. This is the part in your second link.
When Denso says "upstream rear" they mean bank 1 sensor 1. This is what you need.
Tsmalls (03-18-22)
And yes, your part # referenced to Lexus2000 link
Thanx again
The engine is rotated 90 degrees in the engine compartment with the front of the engine on the passenger side. So the right side of the engine (bank 1) is closest to the rear of the car. The left side of the engine (bank 2) is closest to the front of the car. Upstream refers to sensors (sensor 1) closest to the engine. Downstream refers to sensors (sensor 2) further-most from the engine. Downstream sensors are O2 sensors.
I ordered from amazon from you link above. says it will be here fri. from what i've seen, it doesnt seem to difficult. thanx for the help. wish me luck. lol
Well I replaced the sensor this morning. Think it took longer to run up to O'reilly's to get a sensor socket than it did to change the sensor. Disconnected battery to reset lights. Hopefully they stay off. Thanx a bunch for the correct part number.
P0051 is250 rwd 2006
Hi having this error.
low heating circuit.
What oem part is that for bank 2 sensor 1? Is it a same part with bank 1 sensor 1? Is it same for rhd and lhd vehicles (uk us)? Is this part same for other models Ls rx gs?
Cheers
Cheers
