Car wont crank???
Old 03-28-15, 11:58 PM
Dylan97
Dylan97's Avatar
Default Car wont crank???
When i turn it to ACC the electrical shuts down. And it wont crank at all. Tonight, my sunroof is stuck open along with a window.. My positive battery terminal is pretty loose, could this be the problem? if so then i will go buy new terminals tomorrow. if not, what could cause this?
Old 03-29-15, 08:34 AM
tomf
tomf's Avatar
Could be the terminal or the battery. Try fixing the terminal. The battery might need to be recharged.
Old 03-29-15, 09:17 AM
PFB
PFB's Avatar
Had the identical problem several years ago. Picked up a new terminal clamp from the Lexus dealer. Around $15.00.
Takes about 15 min to change. All was fine after that.
Old 03-29-15, 01:11 PM
ES300NZ
ES300NZ's Avatar
Sometimes to can temporary fix the terminal by putting a 'screw' .. um between the terminal and the bolt in this photo. You just have to make sure you don't pierce the battery.
GS-power
06-24-10 06:05 AM
orangecar
Performance & Maintenance
12-08-07 05:54 PM
LEKSO
09-18-06 08:16 PM
arunp1783
Maintenance
26
09-09-05 09:50 AM
Quick Reply: Car wont crank???
