P0125 p1135 p1155 p0171 p1130 p1150
Old 03-28-15, 10:17 AM
artbuc
artbuc's Avatar
Originally Posted by clarky14
They've only had the car for a year or two. Don't know if the throttle body was ever replaced. The car has over 200,000 miles
TB = timing belt. Stretched or skipped a tooth?
Old 03-28-15, 10:54 AM
clarky14
clarky14's Avatar
The previous owner had it replaced before mother in law bought it. Along with the AC comp
Old 03-29-15, 04:37 AM
artbuc
artbuc's Avatar
Please let us know how you are doing with this, especially if you are able to determine root cause for the codes.
Old 03-29-15, 06:11 AM
clarky14
clarky14's Avatar
It looks like there's no fuse in the a/f heater slot. Am I just seeing things? Lol
Old 03-29-15, 06:14 AM
clarky14
clarky14's Avatar
The a/c slot is open too.
Old 03-29-15, 06:56 AM
clarky14
clarky14's Avatar
The sensor by the radiator appears to be newer and it does say Toyota on it
Old 03-29-15, 07:45 AM
artbuc
artbuc's Avatar
So, if the "mechanic" who replaced the A/C compressor pulled the fuses, your MIL would have had the CE light on since the work was done, but you say the light just came on. Can you determine if the "mechanic" who replaced the VVTi sensor actually did replace it? There is more to this story than we are getting.
Here is a good trouble shooting guide: I would guess all of your codes stem from the open A/F sensor heater circuit.
http://www.motor.com/article.asp?article_ID=1643
Old 03-29-15, 08:00 AM
tomf
tomf's Avatar
Wow. I'm stunned that the fuse is missing. And you are only now getting error codes? BTW, I checked both my 99 ES300s. Both have the a/f fuse but do not have the a/c fuse. Is that normal?
Old 03-29-15, 08:07 AM
clarky14
clarky14's Avatar
The AC and timing belt was replaced by the stealership when the previous owner had it over. The timing belt was replaced at 101,000 miles. The AC compressor was replaced at 170,000 miles. The car currently has 201,000 miles. The missing fuse for the AC slot is okay. After looking closer there aren't any metal contacts in the port. I think it's an option for something. The missing fuse in the heater circuit though is quite interesting. I couldn't say if the mechanic who replaced the vvti sensor touched that or not. These codes aren't new though I should say. The light has been on for a month or two. I just found out when they mentioned it and figured I'd help out.
I took the car for a spin to reset the monitors. The first pending code was the P0171. Minutes later a NEW CODE popped up. P0420. I couldn't get the C and EV monitors to reset though. I'm going to clean the MAF now.
Old 03-29-15, 08:13 AM
artbuc
artbuc's Avatar
Did you replace the A/F fuse? On the MAF sensor, make sure you clean the heated wire and not the IAT sensor bulb which is a common mistake. What are C and EV monitors?
Old 03-29-15, 08:21 AM
artbuc
artbuc's Avatar
http://engine-codes.com/p0420_toyota.html
Old 03-29-15, 08:23 AM
clarky14
clarky14's Avatar
We didn't have a 25 amp fuse on hand but we put in a 30 amp. What do you mean clean the heater?
Old 03-29-15, 08:28 AM
artbuc
artbuc's Avatar
Do you know how to clean the MAF sensor? If not, search for tutorials with pics. What you are cleaning are the heated wires deep in the body of the MAF sensor. You must use MAF cleaner and be careful not to damage the wires. There is also a brown tear drop shaped bulb which measures intake air temperature (IAT). Many people mistakenly think this bulb is the MAF sensor.
Old 03-29-15, 08:37 AM
clarky14
clarky14's Avatar
I sprayed MAF cleaner on that wire. And wiped off dust on the plastic housing.
Old 03-29-15, 08:43 AM
artbuc
artbuc's Avatar
You should have seen two wires and the difference between clean and dirty is quite apparent.
http://priusdiy.com/tutorials/engine...wcleaning.html
https://www.celicahobby.com/forums/u...-to-clean.html
Quick Reply: P0125 p1135 p1155 p0171 p1130 p1150
