Is my side window out of adjustment?
Old 03-22-15, 04:52 PM
Oro
Oro's Avatar
Default Is my side window out of adjustment?
Last week I noticed the driver's window shuddered as it was going the last 1/3 the way up - as if it were fighting against the seal (glass run). 2002 ES.
Today I lubed the window run with Sil-Glyde. It helped a little bit, but not much. I put the glass 1/2 way up and then grabbed it and I could easily move it up/down about 1/2" and fore-aft a little less than that. Is that normal? After moving it around, it worked smoothly a few times, then went back to the shuddering as it closed the top 1/3 or so. It does not seem the motor is weak.
Is the glass perhaps loose in the guide and thus dragging in the run? Or is this a sign of something failing?
tman6925
Performance & Maintenance
01-31-19 12:49 PM
Duker3
08-26-16 09:01 AM
khmer470
GX - 1st Gen (2004-2009)
08-25-11 08:14 PM
jaseinatl
SC- 1st Gen (1992-2000)
04-11-10 02:42 PM
lexsc492
11-22-09 02:28 PM
Quick Reply: Is my side window out of adjustment?
