2000 es300 torque specs
Old 02-11-15, 08:49 AM
thomasjti
thomasjti's Avatar
Default 2000 es300 torque specs
Hello does anyone have the torque specs for the intake manifold & plenum bolts for a 2000 es 300 handy? Let me know I appreciate it
Old 02-11-15, 03:38 PM
tomf
tomf's Avatar
I think this is what you want, from a 97 manual: Probably the same.
INSTALL INTAKE MANIFOLD ASSEMBLY
(a) Install the intake manifold, delivery pipe and injectors assembly
with the 9 bolts, 2 plate washers and 2 nuts. Uniformly
tighten the bolts and nuts, in several passes, in the
sequence shown.
Torque: 15 N·m (150 kgf·cm, 11 ft·lbf)
INSTALL AIR INTAKE CHAMBER ASSEMBLY
(a) Using an 8 mm hexagon wrench, install a new gasket and
the air intake chamber assembly with the 2 bolts and 2
nuts. Uniformly tighten the bolts and nuts in several
passes.
Torque: 43 N·m (440 kgf·cm, 32 ft·lbf)
Old 02-12-15, 09:29 AM
thomasjti
thomasjti's Avatar
Thank you I appreciate it!
Old 02-12-15, 07:51 PM
Ezcal
Ezcal's Avatar
Just to confirm, those are the same numbers I'm seeing in the 2000 Factory Service Manual as well.
artbuc
03-07-16 01:58 PM
Parfive00
01-06-16 12:13 PM
c50sooner
10-01-13 03:31 PM
v12mac
01-23-09 04:27 PM
Dx3
SC400 / 300 Classifieds
03-18-08 02:48 PM
Quick Reply: 2000 es300 torque specs
