P0420 & P0420 pd codes - help
Old 01-29-15, 10:44 AM
EPayne42
EPayne42's Avatar
Default P0420 & P0420 pd codes - help
Hello ...1999 ES300 is throwing the dreaded P0420 and P0420 pd codes. I had an axle seal that was leaking ATF. It dripped (and burned off) on the exhuast ...then the codes came. Was thinking the heat generated by the ATF burning before the cat caused the system to read hotter exhaust temp on the entry side of the cat. The leak is fixed, but still getting the codes. I cleared them a couple times. They pop up after about 30mins of driving.
I know these codes have been discussed at length, but wanted to start a new thread as my leak situation may have added a new twist. The advice I read was start with swapping Sensor 1 Bank 1 (near firewall), but most likey I have a bad cat.
Any advice/personal experience is greatly appreciated.
Old 01-29-15, 04:55 PM
ES300NZ
ES300NZ's Avatar
Trouble Code - P0420 Catalyst System Efficiency Below Threshold (Bank 1)
There are two o2 sensors in the system, one before the cat, one after. (there's also a a/f sensor).
The difference between the sensors o2 sensors is how the system comes up with this code. (or rather the lack off)
You can either replace the CAT (which is likely the issue), or both o2 sensors on that bank. Good o2 sensors are always a wise investment for fuel injected car, as they form the very basis of the electronic fuel management system. But, you can also do nothing. It's not a series code, you can safely ignore it.
Old 01-30-15, 08:41 AM
EPayne42
EPayne42's Avatar
Thank you sir. I will start with the o2 sensors. They're not cheap as you know, but obviously easier to swap than a cat.
Any recommendations on a replacement cat? I've seen a Bosal cat online. As I recall, Bosal is a reputable brand.
Old 01-30-15, 09:32 AM
Wht95scort
Wht95scort's Avatar
Before condemning a bad cat you need to make sure you have no exhaust leaks that could be drawing in extra oxygen before the O2 sensor. Typically a smoke test is used for this. If no leaks are found you have a bad cat. The O2 sensors job is to detect well oxygen. Too much it knows hey this cat isn't doing its job and a code is set. It also will think the car is running too lean and will start to add fuel giving you a rich condition and causing bad gas milage as well could damage the O2 sensor. Look for leaks first.
Old 01-30-15, 11:05 AM
EPayne42
EPayne42's Avatar
Yep... we're seeing the fuel economy drop. I'll do the leak test around the headers and y-pipe. I may try swapping that bank 1 sensor 1 o2.
Old 01-30-15, 12:20 PM
PFB
PFB's Avatar
Watch this YouTube video. It will help you determine if your Cat converter is functioning correctly or if ts defective. It will also help you diagnose your P0420 code.
A must viewing.
Phil
http://www.youtube.com/watch?v=9VZ5K...e_gdata_player
Old 01-30-15, 04:21 PM
EPayne42
EPayne42's Avatar
A must viewing.
Phil
Thanks Phil! I need to upgrade my scanner
STREETGS
12-26-19 02:34 PM
mre2000
02-03-13 06:21 PM
colenzae
RX - 1st Gen (1999-2003)
12-02-09 12:49 AM
j_version_
03-06-09 02:50 PM
UncleRay
Maintenance
03-06-08 05:13 PM
Quick Reply: P0420 & P0420 pd codes - help
