A/C Leak - ES300, need advice
Old 01-29-15, 09:24 AM
EPayne42
EPayne42's Avatar
Default A/C Leak - ES300, need advice
Hello,
Looking for help on an A/C Leak. 1999 ES300. A/C was not working when car was purchased (about a month ago). I filled the system with R134a (jumped the compressor clutch) and the system stayed cold for about 5mins. I ran a dye test and the dye shot out of a nipple on the back of the compressor (see photo). Anyone know what this is? Have you experienced this before? Common issue?
Old 02-01-15, 06:15 AM
EPayne42
EPayne42's Avatar
BUMP,
What I thought was the source of a leak was actually a pressure safety valve. I had over filled the system and valve opened.
I evacuated the system, then ran vacuum, then refilled the system. No leaks. The gauges have perfect readings. The problem is the compressor won't click on (unless manually jumped). I played with the safety pressure switch at the receiver/drier. I removed the connection and the a/c fan turned on immediately, but the compressor still didn't kick in. Hmmmm. I'm suspecting my pressure switch.
Stilll needing advice on this.
Xaelle
08-22-14 05:21 PM
BartleDoo
Performance & Maintenance
07-13-11 09:36 AM
Hilux22RE
07-05-11 12:27 PM
lexus72
35
07-21-09 07:34 AM
Taka
SC- 1st Gen (1992-2000)
08-11-01 10:12 PM
Quick Reply: A/C Leak - ES300, need advice
