Lexus ES 330, Car Alarm went off frequently..
Old 01-14-15, 07:32 AM
KevinVinhL
KevinVinhL's Avatar
Default Lexus ES 330, Car Alarm went off frequently..
I have a Lexus ES 330. My car alarm went off frequently that kills my battery.
It went off without a reason =( I ha e to wake up manytimes at night to hit the open key to turn off the alarm. Anyone knows why does this happen?? Car key problem or the door problem?
Thanks everyone in advance.
Old 01-14-15, 08:54 AM
BDSL
BDSL's Avatar
Does the alarm only go off at night? If so, then someone is trying to break into your car.
If the alarm goes off throughout the day/night, then you might have electrical issue.
Old 01-14-15, 05:43 PM
speedkar9
speedkar9's Avatar
Check your door switch. Likely the driver's side since that gets used more.
If it only happens at night it could be the cold causing contacts to contract and complete the circuit.
Old 01-14-15, 06:33 PM
KevinVinhL
KevinVinhL's Avatar
Thanks everyone, it went off day/night =( the neighbor gonna kill me soon =#
I'll check the switch, thanks for the advice Speedka9
Old 02-27-15, 02:52 PM
tagcvg
tagcvg's Avatar
Default to Kevin Vinhl
Did you find the reason your es330 2005 Lexus kept alarming in the cold? We are having the same problem and so far no one has been able to help us. Did you change the switch on the driver's door and if you did.... did it stop the car from alarming in the cold? Anything you can tell us will be appreciated. Cannot use the car with this problem. If you changed a switch, which one was it? Thanks
Old 02-27-15, 06:20 PM
Mphidd
Mphidd's Avatar
My 99 ES has an alarm that goes off if I try to open the car from driver side. It didn't do that when I first got it but after about two weeks it started doing it. If the alarm goes off I have to go over to the passenger side and use the key in the door and that ****s the alarm off. I'm taking it to an auto locksmith this week to order a new remote and key since all I have is the key currently. Maybe he can give me some insight as to why this is happening.
mlee934
Performance & Maintenance
02-02-19 12:15 PM
chelli
SC- 1st Gen (1992-2000)
08-04-10 11:34 AM
mac187
GS - 1st Gen (1993-1997)
12-09-08 03:14 PM
fangtl
10-14-06 01:58 PM
additude
RX - 1st Gen (1999-2003)
02-15-02 07:26 AM
Quick Reply: Lexus ES 330, Car Alarm went off frequently..
