--Idle Air Control Valve diy?
is there a diy? i'm having issues with mine in the mornings and it;s getting worst... i've had it cleaned twice previously by a shop though
cause i've been through this 2 times before, the symptoms are the same....cold start the car dies unless i give it gas and it's fine once it's warm and it drive off
Skip to 2:30 to see how the cleaning is performed.
Optional: Skip to 10:54 for an in depth look.
Here is the best and most effective method at cleaning the IACV, I found a good video to explain the process in detail. Be warned that you may end up stripping the screws out, so get a nice fitting screw driver with a T Handle, to give you better control.
#372 Better repair method Toyota Camry Idle Air Control Valve - YouTube
LScowboyLS
03-17-14 03:42 AM
