Knock Sensor p0330 appears even after replacement of the sensor
Old 10-07-14, 01:16 PM
novosartov
novosartov's Avatar
Exclamation Knock Sensor p0330 appears even after replacement of the sensor
Hello Everyone ,
Could you please help me. I have 2001 es300
I had code p0330 Kncock Sensor Bank 2 error so me and my dad decided to replace it ourselves. So we bought 2 sensors bank 1 and bank 2 wiring gaskets and ever tying. After we replaced it we got same error for same bank 2.
Then i decided to try this hack : https://www.clublexus.com/forums/rx-...ck-repair.html
So i connected wire that coming out of computer for bank 2 to bank 1 wire and now i got check engine for bank 1.
So right now i have an error for bank 1 after that wire trick, but originally it was bank 2.
Please help! Knock sensors replaced wiring for those that come in the kit replaced. I don't know what to do.
Is it bad computer?
Thank you in advance
Old 10-07-14, 02:34 PM
Bk2
Bk2's Avatar
Did you do this while the battery was connected? If so try disconnecting the battery give it some time to reset and see what happens. Happened in my 98 es300 with o2 sensors, I didn't turn the battery off long enough when I first did the repair so it didn't reset correctly and the check engine light reappeared under a different bank. Since that has to do with air I drove it a little an took out the battery for a couple hours your usually only need about 15 min. (Just wanted to be sure) Put the battery back in and have been driving without problems ever since; really came in handy as I was due for inspection. As for the hack I personally wouldn't do it but if u tried it one way and it didn't work try it the opposite way.
Old 10-07-14, 02:44 PM
PFB
PFB's Avatar
I can bet you that you purchased aftermarket knock sensors. Those seldom work properly with this car.
Even though they cost alot more, when it comes to knok sensors, only original Lexus knock sensors should be used.
An aftermarket Wiring harness should normally be ok, but for the difference in price, I would still go for an original Lexus wiring harness.
Phil
Old 10-07-14, 03:15 PM
novosartov
novosartov's Avatar
I tried resetting with discounting battery . Also, i have software on my laptop so i connected to car and reset it that way too.
Old 10-07-14, 03:17 PM
novosartov
novosartov's Avatar
Phil
Yes i bought two knock sensors of ebay. But if they were bad i would guess the check engine would come back with two sensors . But i got check engine for the same bank 2 again after replacing.
I agree with using original oem parts but did not have a lot of money at the moment.
Old 10-07-14, 09:15 PM
Hayk
Hayk's Avatar
Sounds like you have a wiring issue, not a sensor problem.
http://www.obd-codes.com/p0330
crawdawg
09-23-19 10:34 AM
Bluv
11-09-15 01:28 PM
shahzach
06-07-14 09:52 PM
mitmaks
09-26-13 08:57 PM
Quick Reply: Knock Sensor p0330 appears even after replacement of the sensor
