98 Es300 Line out converter
I have a 98 es300 and I'm looking to put in an aftermarket amp and subwoofer in the trunk. I do not want to go through taking out the factory amp. I did disconnect the factory sub tho. So my question is is it alright to connect a line out converter for the new amp to the wires for the factory sub? I'm not sure because I know those factory sub wires would still be getting signal from the the factory amp, but then again all the speakers would. So what should I do? Don't wanna fry anything. Thanks.
Not sure if you can do it that way. But here's the way I did it. I spliced the line out converter to the front / left positive negative cords on the amp. The amp is pretty easy to get to. It's underneath the glove box. Hooked up 2 12's with 1,000 watt amp and it sounded great. I'm on my phone right now or else I would give you a link to the wiring diagram. It's not too hard to find. Good luck
Oh yea, you don't have to take out the factory amp. You just need to access it.
bchboyfm82
05-28-14 01:39 PM
SCFriend
13
07-13-04 04:45 PM
