puddles causing power steering loss?
Old 09-10-14, 08:33 PM
jgrosey
jgrosey's Avatar
Default puddles causing power steering loss?
For the second time in about a month, I lost power steering (partially) after driving through a fairly large puddle. I believe last time this happened, I also had to disconnect then reconnect the battery before it started. From reading threads here, it seems like one of two things:
1) distributor cap and rotor need to be replaced
2) water causing belt to slip
How do I go about figuring out which one it is?
Thanks!
Old 09-10-14, 09:26 PM
Received 2,712 Likes on 2,297 Posts
Stop driving through puddles?
Old 09-10-14, 09:31 PM
ES300NZ
ES300NZ's Avatar
or you aqua planned.
Old 09-10-14, 10:02 PM
Hayk
Hayk's Avatar
What vehicle do you drive? Year and model please.
Old 09-11-14, 06:48 AM
jgrosey
jgrosey's Avatar
2000 Lexus ES 300... and I wish I could just stop driving through puddles but it's going to happen occasionally. I mean I didn't go through it super fast or anything.
Old 09-11-14, 06:57 AM
mitmaks
mitmaks's Avatar
You dont have distributor. If water gets on belt it might cause it to slip, partially disabling power steering.
Old 09-11-14, 07:01 AM
jgrosey
jgrosey's Avatar
Hmmm is there any way to fix it? Just get a new belt because mine is worn?
Old 09-11-14, 07:25 AM
BDSL
BDSL's Avatar
Clean your belt with brake cleaner. Adjust the tension if needed.
The belt should be replaced when you replace the timing belt.
Braz60
07-15-16 08:13 AM
gtstcactus
03-29-15 08:17 PM
phonzie
06-14-14 06:16 PM
skiptomylo
14
02-03-12 09:34 AM
ArmyofOne
Maintenance
11-05-04 07:18 PM
Quick Reply: puddles causing power steering loss?
