tutorials on how to install OEM auto dimming rear view mirror?
Old 08-30-14, 04:27 PM
5ltrbeater
5ltrbeater's Avatar
Default tutorials on how to install OEM auto dimming rear view mirror?
a quick search online helped me find threads on how to install an aftermarket one. is there any threads on how to install an OEM one?
(for a 99 Lexus ES300 of course)
Old 08-31-14, 07:42 PM
5ltrbeater
5ltrbeater's Avatar
ttt ttt ttt ttt
Old 09-01-14, 08:25 AM
Hayk
Hayk's Avatar
Check out the link in my signature. There should be a link within that thread about removing the stock radio.
Old 09-01-14, 09:53 AM
Fritz330
Fritz330's Avatar
Did I miss something?
Old 09-01-14, 07:35 PM
5ltrbeater
5ltrbeater's Avatar
sry booby, how does an removing the stock radio allow me to wire in an auto dimming mirror?
the cable provided with the OEM mirror is to 5 to 6 inches long and looks like it plugs into something already inside the controls for the sunroof.
I'm confused.
Old 09-02-14, 05:27 AM
speedkar9
speedkar9's Avatar
Here's a tutorial for a Gen 6 Camry. The procedure should be similar.
http://www.toyotanation.com/forum/10...r-install.html
Old 09-02-14, 11:26 AM
Hayk
Hayk's Avatar
I'm confused.
I should have read the whole title of this thread. Thought you were installing an OEM radio.
Old 09-02-14, 10:32 PM
5ltrbeater
5ltrbeater's Avatar
alright, I just took apart the overhead console and I'm not pre-wired for an auto dimming mirror. I dont mind the challenge and buying one and cutting off the plug, and wiring it in myself (I'm assuming that the mirror just needs a positive and negative to operate)
but when I look at the wires in the pics of the auto dimming oem mirror, it appears that there are 3 wires and not just two.
what could the other wire be for?
Old 09-03-14, 05:22 AM
ayonnebay
ayonnebay's Avatar
I put an OEM mirror in my '98 ES some years ago, and recently took it out (as I'll be selling the car). It had only two wires -one to be connected to the hot (when ign is on) and the other to be grounded under a chassis screw. They went to a connector to be plugged into the back of the mirror. I had connected them to the roof console - the "+" tapped into a sunroof switch wire, I believe.
OEM Toyota P/N PT732-33000 Mirror, EC. RR View (Electrochromic mirror w/Compass)
Walt
Old 09-03-14, 09:25 AM
5ltrbeater
5ltrbeater's Avatar
interesting. guess I'll buy it and check it out. I read the tutorial for installing the aftermarket one and I know where to get power from so I'll just take a chance and see what happens and report back.
Old 09-03-14, 09:31 AM
5ltrbeater
5ltrbeater's Avatar
http://www.ebay.com/itm/00-01-Lexus-ES300-OEM-Gray-Rear-View-Mirror-w-Auto-Dim-/191295525297?pt=Motors_Car_Truck_Parts_Accessories&hash=item2c8a1a11b1&vxp=mtr
as you can see in the above link, there seems to be actually 4 wires instead of 3 that I thought. dammit : /
Old 09-03-14, 09:35 AM
5ltrbeater
5ltrbeater's Avatar
Walt
dam! that thing is $250+ dollars
Old 09-04-14, 07:27 AM
ayonnebay
ayonnebay's Avatar
Naw, .... Keep looking. While I bought mine for, I believe $120 or so, back in the day, I've seen it recently marked down to around $49. Did you Google it?
I PM'd you
Walt
a11179a
10-30-17 06:41 PM
door
12-15-12 12:12 AM
billyboy
RX - 1st Gen (1999-2003)
09-25-02 09:32 PM
Quick Reply: tutorials on how to install OEM auto dimming rear view mirror?
