Help please !
Old 08-05-14, 05:12 PM
user 72082
2nd gear
user 72082's Avatar
Arrow Help please !
I got a 2002 Lexus ES 300 . I have two questions #1 when I first start my car and turn my air on it squeaks really bad in drive then it stops . Do I need a another compressor ? The air is still very cold . Question #2 my fan use to blow very hard . I think it had five bars for the level of air . But now I only got three . Can I fix this or do I have to buy a new compressor and fan motor ? Thanks for your help ! Black whip
Old 08-05-14, 06:04 PM
3ztwint
3ztwint's Avatar
The squeak is likely just your AC comp belt, if it still gets cold your comp should likely be fine. The "3 bars" could be anything from a climate control board logic error to a simple fix like your fan speed rheostat. I've never seen one of these where the fan speed only worked up to 3 clicks. If the rheostat goes bad you usually have only high speed, not sure if there is even a rheostat on the digital climate controls tho, so you may just need a new climate unit, but I'd ask around more before just replacing
Old 08-05-14, 07:42 PM
user 72082
2nd gear
user 72082's Avatar
Thank you sir for your advice ! I'm going to give it a try . Black whip .
Scarby
SC- 1st Gen (1992-2000)
07-09-18 12:03 AM
jabo75
06-03-14 05:10 AM
VC455
09-21-12 06:45 PM
boosst
05-08-07 08:19 PM
Quick Reply: Help please !
