Go Back   Club Lexus Forums > Lexus Model Forums > ES Models > ES300 and ES330
Sign in using an external account
Register Forgot Password?
transmission fluid change 2006 es330
Thread Tools Search this Thread Display Modes
Old 08-04-14, 02:47 PM   #1
lostang
Trader Score: (0)
Default transmission fluid change 2006 es330
My wife called dealer last week and they wanted something like $169 or so to do a drain and fill.
I told her let me order fluid and i'll do it once it comes in. well it came in today and decided to get it over with and just do it. Did a youtube search and looked to be one bolt. I used a T55 star bit socket.
looking at some old receipts i found that last owner did it at 65k miles. Today, it has 132k miles and to tell you the truth oil did not look too bad.
So for anyone thinking about doing this, its super easy and took maybe 20 min max. I paid $27 for 4 quarts of Toyota fluid online.
http://tinypic.com/r/ojgeup/8 (took short vid. should have taken vid right as i removed bolt)
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
lostang is offline   Reply With Quote
Old 08-04-14, 05:13 PM   #2
01LEXPL
Trader Score: (10)
01LEXPL's Avatar
4qts? Seems a little low...
I'd check those fluid levels if I were you...
01LEXPL is offline   Reply With Quote
Old 08-04-14, 06:32 PM   #3
pauloil
Trader Score: (0)
the bolt is 10mm hex on the inside and it take 3.7 qts to refill after draining transmission
pauloil is offline   Reply With Quote
Old 08-04-14, 07:10 PM   #4
speedkar9
Trader Score: (0)
speedkar9's Avatar
I did mine a few months ago:
www.youtube.com/watch?v=_W5OK9XgbNw
__________________
2005 Lexus ES330
1999 Toyota Solara
Youtube DIY Videos: www.youtube.com/user/speedkar99
speedkar9 is offline   Reply With Quote
Old 08-05-14, 05:23 AM   #5
BDSL
Trader Score: (0)
I have a 2006 ES330.
You will need 4 qts of Toyota T-IV fluid, a 10mm hex, and the crush washer for the drain bolt.
The job will take 10 mins depending on how good you are.
BDSL is offline   Reply With Quote
Old 08-05-14, 08:59 AM   #6
lostang
Trader Score: (0)
No, its a little less than 4
Old 08-05-14, 03:54 PM   #7
brucelee1
Trader Score: (1)
3.5 qts in my car. I have done this about 5 times, same volume everytime.
brucelee1 is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
Transmission fluid change masterluna IS - First Generation 2 11-25-14 07:55 AM
Transmission Flush by Toyota seabee7196 ES350 (2007 - 2012) 1 04-13-14 08:36 PM
2008 GS 350 Transmission Fluid HELP! d4vid GS - Third Generation 13 09-25-13 08:48 AM
Drain and fill transmission fluid - made a difference hardimen RX - Second Generation 11 10-02-12 12:51 PM
Need to change fluidson 01 GS430, any thoughts? Panerai127 GS - Second Generation 28 01-30-07 04:55 PM
Tags
es330, fluid, lexus, transmission
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join ClubLexus
Copyright © 2000-2015 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
Get all contact info
