Help, 93 es300 over heats
HI there! I own a Lexus ES 300 and it has started overheating recently . When it first happened I checked under the hood and realized the coolant was running out of the drain hose near the coolant reservoir. I replaced with a new coolant filler cap which hooked up to a drain hose and filled the coolant, the engine's heat stayed at the halfway point for about 10 minutes then climbed up to red. I polled over and checked the drain hose found the coolant was still running out and boiling.
PFB
03-13-17 04:51 PM
squ
13
01-13-06 09:35 PM
