Need help identifying part on 99 ES300
Old 07-20-14, 06:51 PM
is503
is503's Avatar
Default Need help identifying part on 99 ES300
Does anyone know what these sensors are? They're off of 99 ES300. One of them was broke when I tried to removed it.
Pic taken from the front. You can see 2 small tubes running to one of the sensor. This is the front one isn't broken, you can see the orange plug toward the rear on the right side that is broke.
Rear sensor that is broken and need replacement.
Old 07-20-14, 08:48 PM
Received 2,712 Likes on 2,297 Posts
It's a vacuum switching valve, best to seek one out at an auto wreckers new they are $130+. Both are the same BTW.
Old 07-20-14, 08:52 PM
LexusElite
LexusElite's Avatar
+1 wrecking yard is your cheap option.
Old 07-21-14, 02:27 AM
is503
is503's Avatar
Do you guys know what year the camry v6 or avalon that would have the same valve?
Old 07-21-14, 08:04 AM
Mythotical
Mythotical's Avatar
1996-1999 1MZ-FE any of them. I have a couple of spares I keep on hand should the day come.
Old 07-21-14, 11:23 AM
is503
is503's Avatar
Just got it from ebay for $21shipped.
thanks guy. I was in the process of changing out #3 and #4 coil, and broke the the vaccum switch trying to remove the hose. I didn't have to remove the intake manifold to swap out the rear coil. I might just replace all the spark plugs this weekend too. I should have the car back together this weekend.
saggy007
24
03-20-20 11:48 PM
mhusted318
06-26-17 09:53 AM
djdan017
01-28-11 04:53 PM
PeterR1
07-07-09 05:36 PM
Quick Reply: Need help identifying part on 99 ES300
