strongarm hood strut/support issues?
Old 06-29-14, 04:06 AM
gabzor
gabzor's Avatar
Default strongarm hood strut/support issues?
i have a 95 es300, and i installed the strongarm hood struts/supports but the hood didn't seem to sit right so i kind of slammed the hood and forced it but it (by putting butt to hood and bouncing on it)
but it still didn't sit right..
the next day, i open my hood and tried to remove the strut/support to maybe reinstall it, and actual strut/support broke off the hinge
btw i used the aftermarket hook bolts or whatever the strut attaches into, because i literally couldn't remove the oem ones, maybe if i cut it i could have had access to it
so i contacted the seller, and he sent me a new pair, and i tried installing and adjusting about 10 times, but the hood still doesn't sit flush..
anybody else have this issue? any fixes?
thanks
Old 06-29-14, 04:19 PM
artbuc
artbuc's Avatar
thanks
Sounds like you damaged your hood. May need a trip to the body shop. Did you really force the hood by bouncing your butt on it? If you did, it is the dumbest thing I have ever read on a DIY automotive forum.
Old 06-29-14, 05:53 PM
gabzor
gabzor's Avatar
yeah i did, but it didn't close fully, those struts are rated like 250lb each
Old 06-30-14, 01:44 AM
artbuc
artbuc's Avatar
The struts may be rated for 250 lb but the hood isn't. You most likely sprung your hood and/or your hood hinges. Good1luck with that.
shboni
02-23-16 10:59 AM
ThumperPup
ES - 5th Gen (2007-2012)
11-23-14 01:37 PM
SC4ME
SC- 1st Gen (1992-2000)
10-22-13 11:43 AM
toytrain13
09-27-12 05:34 PM
lexuslspro
09-23-10 07:17 AM
Quick Reply: strongarm hood strut/support issues?
