Need help identifying these broken parts!
Old 06-15-14, 10:59 AM
PDXLex
PDXLex's Avatar
Default Need help identifying these broken parts!
Looks like these two parts are the culprit of my broken door handle. The little broken yellow clip on the rod is what connects to my handle. The wire with the strange white connector thingy buts up against the back of the lock tumbler. It snapped when the window dropped and pulled on it. Anyone know what these parts are called or the part numbers? Car is an '00 ES 300, driver's door .
Old 06-15-14, 11:10 AM
PDXLex
PDXLex's Avatar
Here's the other pic that didn't upload
Old 06-15-14, 11:21 AM
mitmaks
mitmaks's Avatar
One with yellow clip goes on inside of door somewhere.
Old 06-15-14, 12:31 PM
PDXLex
PDXLex's Avatar
Yeah, I definitely know where all the parts go, but I need to what they are called or the numbers for ordering purposes. That wire seems to play a roll in the remote unlock/lock feature. It mounted up against the lock tumbler, but now it's broken off so it won't stay on anymore. The little yellow clip holds the rod to the back of the door handle.
Old 06-15-14, 12:55 PM
Hayk
Hayk's Avatar
Try one of these for the Front Door
http://lexus.sewellparts.com/oem-cat...S300-1998.html
Old 06-15-14, 01:13 PM
afang
afang's Avatar
For my 98 I replaced the clip (snap, door) part number 69293-12040. cost $6.12 at a local Lexus dealer. The clip was extremely tight and was difficult to insert into the hole in the door handle and then insert ing the linkage was worse. It would have helped, i believe, if I had reamed out the hole that the linkage passes through. The electric device that came off the door lock does not seem to effect the electric door locks. i think it is part of the security system. My door locks work fine without it.
Old 06-15-14, 02:34 PM
PDXLex
PDXLex's Avatar
Thanks Afang, I'll definitely get that $6.12 clip and hopefully that will solve the problem. That electronic device seems to have something to do with the door locks, because now I can't remotely lock the doors. Oddly enough I still can remotely unlock the doors with that cable completely removed. When I looked up parts diagrams, I found 'PNC 84903' looks very similar to what I have. When I performed a google search, I see numerous Toyota sites referencing this part as a
'Switch Sub Assembly Door Unlock' but no mention of Lexus makes or models.
sho89mtx
07-15-13 10:38 AM
Bri-Guy
05-17-08 07:45 PM
Dx3
SC- 1st Gen (1992-2000)
17
01-11-05 09:22 PM
Dx3
10-28-04 04:24 PM
Quick Reply: Need help identifying these broken parts!
