Driver's door won't open from outside
Old 06-15-14, 12:13 AM
PDXLex
PDXLex's Avatar
Default Driver's door won't open from outside
My '00 ES 300 suddenly will not open from the outside door handle. The inside handle, power locks and keyless entry work fine, but the outside door handle feels like it extends upward much more than the other three doors. I can only open the door from the inside. Clearly, something is wrong with the outer handle. I also noticed when I lowered and raised the window, I heard a clicking/popping sound. Anyone else had this happen before? I have the shop manual and I'm going to disassemble the door panel tomorrow... Anything specific I should be looking for? Thanks in advance
Old 06-15-14, 11:40 AM
Chuckinnj
Chuckinnj's Avatar
Most likely the rod came off the door handle or a door handle piece broke off..... Should be a EZ Fix.
Pull the interior door panel off and look inside the door at the door handle..... You will what is happening.
Old 06-16-14, 07:07 PM
PDXLex
PDXLex's Avatar
This little part turned out to be the problem. The plastic got old and brittle and snapped. Picked it up for $3.07 at the Toyota delaership. It's in kind of a tight area to access and involved taking the door panel apart, but it sure beats paying the Lexus dealership $150 to do it!
Old 06-16-14, 07:09 PM
Chuckinnj
Chuckinnj's Avatar
Yup!..... That's what I thought it would be.
Old 01-31-16, 10:52 PM
lennysmith
lennysmith's Avatar
Well I haven't done this by myself for once because i always hire the locksmith for repairing the car door locks.How much time it will take to repair the door handle locks because i think i should try repair this by own . .
Old 06-02-16, 12:35 PM
dpwct
dpwct's Avatar
Do you know the part number - the manual door button near the handle on my 2003 es300 is not working - did your not work either?
The outside handle works, but the inside handle does not unlock the door when pulled.
Old 07-08-16, 06:47 AM
chuckerst
chuckerst's Avatar
did you have to remove the window to get to that-i couldn't do it without taking out the door glass!
Old 07-08-16, 08:44 PM
speedkar9
speedkar9's Avatar
No but you have to take the handle out of the door skin and remove that rod connector from the outside of the vehicle.
See this video:
Old 08-04-19, 12:03 PM
Twoz
Twoz's Avatar
Hi. Will part 69293-12040 fit 1995 Lexus sc400 driver side (left).
Old 08-04-19, 12:24 PM
Received 2,712 Likes on 2,297 Posts
I don't know this is the ES forum ask your question here
https://www.clublexus.com/forums/sc-...n-1992-2000-6/
Old 11-14-22, 08:10 PM
AndrewLWSN
AndrewLWSN's Avatar
Go to a body shop to get an inspection/quote. Something similar happened to me about 6 months in after buying my ES in Caviar 3 years ago on the rear passenger door. The body shop (called Fix Auto ; pretty known chain where I live) was able to repair it and you can't even tell it was hit. I was incredibly surprised by the result and how they managed to do it (even when you try to inspect it with the light reflection, you couldn't tell). I paid around 600$ CAD.
Helogadget
07-01-15 03:12 AM
vinsonF
IS - 1st Gen (2001-2005)
05-03-15 03:29 PM
linx
02-01-09 04:24 AM
mr nut
SC- 1st Gen (1992-2000)
12
09-25-07 05:37 PM
daytripper
01-04-04 04:43 PM
Quick Reply: Driver's door won't open from outside
