Transmission not shifting into over drive sometimes
Old 06-04-14, 04:28 PM
ES300doc
ES300doc's Avatar
Originally Posted by Bumbobee
Ok I bought 2 new knock sensors and 2 new wiring things. What else do I need for this job? Intake manifold gasket? Which one? Just the upper or lower or both?
You will need an intake manifold gasket set. This will include the lower intake gaskets and upper plenum gasket. I usually by the set in Felpro from the auto parts store. Quality is excellent. If your going another route, you will need the lower intake gaskets and one upper plenum gasket.
Since your going to have the upper plenum off, now would be a good time to do the valve cover gaskets , unless they have already been done recently.
Old 06-05-14, 07:20 AM
Bumbobee
Bumbobee's Avatar
My mechanic is asking $ 400 to change the sensors with wiring harness, replace intake manifold gasket, and valve cover gasket.
I am supplying all the parts.
Is this a fair price? Seems expensive to me...
I am in Canada so everything here is more expensive including labor.
Old 06-05-14, 08:35 AM
Received 3,044 Likes on 2,558 Posts
Price is not that bad, replacing the knock sensors is a lot or work.
Old 06-05-14, 08:39 AM
Bumbobee
Bumbobee's Avatar
I asked another guy today and he said I should just try using higher octane gas and maybe the problem will go away? I use 87.
Old 06-05-14, 09:58 AM
Doubt it. The ECU looks for a signal from the knock sensors all the time not just when knock is detected. This is done so that if a sensor is bad you get a CEL right away, waiting for the engine to knock when a sensor is bad would be hard on the engine.
Old 06-05-14, 10:39 AM
Bumbobee
Bumbobee's Avatar
Alright man going to change everything out next week. Just waiting on the gaskets to come in. Pray for me that it works, I dropped so much cash into this car lately it's pure madness
Old 06-05-14, 11:06 AM
You should return those sensors and buy from Toyota. The ones you bought could be fine but they could cause problems which tends to happen with aftermarket knock sensors most of the time. Yes they cost more than aftermarket but it will cost you even more if you have to do the job twice.
Aftermarket parts are often a false value.
Old 06-05-14, 11:45 AM
Bumbobee
Bumbobee's Avatar
Just called lexus $ 230 plus 13 % tax for each sensor...
I'll take the gamble with aftermarket
Old 06-05-14, 12:18 PM
PuReChaos
PuReChaos's Avatar
You could grab both from Sewell for around 138 each. Unfortunately I'd assume shipping international would be at least double what we pay so probably like 30-40 dollar range putting it just above 300 for both. Hope the aftermarket some how work out for you.
Old 06-06-14, 06:44 PM
01LEXPL
01LEXPL's Avatar
Story of my life
Hopefully I'll see some of it back... eventually.
Old 08-02-14, 01:32 PM
rja
rja's Avatar
Default O/D not working
My 1999 ES300 is apparently one of many with the same issue. Engine light and traction light are on and Overdrive does not work most of the time. I have driven it this way for about 4,000 miles. Now, first gear is also slipping sometimes. I have read many post, but have not seen definitive answer. I assume new transmission is needed. Does anyone have idea how much this would cost? Car has 140,000 miles and wonder if car is worth fixing. I am new to club and don't really understand the post/threading process. Is that explained somewhere? Thanks!
Old 08-02-14, 06:29 PM
pauloil
pauloil's Avatar
your post is fine. try a drain and fill with the tranny first
get your codes read and post them here. driving like that for 4K miles is asking for troubles. these engines are finely tuned.
Kauaiguy
RX - 1st Gen (1999-2003)
09-29-22 02:38 PM
Gmsd
08-09-17 05:50 PM
tomtam6
08-28-13 01:31 PM
Quick Reply: Transmission not shifting into over drive sometimes
