Knock Sensor Problem
Old 03-10-14, 04:56 PM
shahzach
shahzach's Avatar
Default Knock Sensor Problem
Hi,
2000 ES300 both knock sensor code is genrating CEL , I have replaced knock sensors , knock sensor harness, checked the contineuty of wire for knock sensor to ECM( contineuty is ok) , also checked shileded negitive wire (neg power is present) in harness, engine runs smooth only the transmission does not go to overdrive , i also replaced the ECM same codes came up for knock sensors.
Please help me out.
thanks in advance
Old 03-10-14, 05:19 PM
PFB
PFB's Avatar
Did you buy original Lexus/Toyota knock sensors, or after market ones?
After market ones seldom work properly in this car.
Old 03-10-14, 08:27 PM
PuReChaos
PuReChaos's Avatar
I second PFB.
I think your problem is coming form the sensors themselves. Did you test the knock sensors themselves to see if they might be shorting themselves? Take the ohm meter and check if there is continuity from the wire to the sensor body. Obviously there should be none. Another thing to check would be are the sensors installed tightly to where they won't wiggle around causing them to throw a code? Lastly, the ECM could be at fault, however, without knowing exactly what happened to begin with I wouldn't condemn the ECM first as its the more expensive to replace.
Old 05-24-14, 04:28 PM
shahzach
shahzach's Avatar
hi
PFB is absulatly right , when my mechanic changed the after market to original knock sensors car got great ride.
Old 05-24-14, 06:37 PM
ES300doc
ES300doc's Avatar
Lexus knock sensors self generate a low voltage signal when they sense engine knock or ping. They might be functioning as designed. Exactly what codes are showing up?
Old 05-24-14, 09:47 PM
shahzach
shahzach's Avatar
p0325 and p0330
Old 06-04-14, 08:49 PM
fdmt
fdmt's Avatar
Had exact problem. Just replaced the two sensors with known good factory sensors and problem solved. I have a ecu with chip for sale if anyone is needing one. Aftermarket sensors were the problem.
Old 06-07-14, 09:52 PM
Mythotical
Mythotical's Avatar
What kind of chip?
MsbTTSupra
02-21-20 07:27 PM
O1GS43O
RX - 1st Gen (1999-2003)
05-27-11 09:37 PM
driverJM
03-27-11 05:06 PM
Quick Reply: Knock Sensor Problem
