Help fan not turning on
Old 02-09-14, 11:39 AM
Dvinhie
Dvinhie's Avatar
Default Help fan not turning on
I was driving on the road yesterday and smoke came out on the radiator cap. I had changed the themostat and the switch on the right side near the thermostat house. Yet the fan is still not turning on. I also pulled out the relay and that does not seem to be the problem. 1997 lexus es300
Old 02-09-14, 01:50 PM
mitmaks
mitmaks's Avatar
Check the actual fan motor to see if it's not burnt out.
Old 02-09-14, 03:48 PM
310V6
310V6's Avatar
When you where overheating, what did the temperature gauge say?
Old 02-09-14, 08:28 PM
Dvinhie
Dvinhie's Avatar
The car temperature alway stay in the middle for some reason. The fan had been changed a month ago since the fan shroud broke off.
Old 02-09-14, 08:31 PM
Dvinhie
Dvinhie's Avatar
I brought the car a couple month ago. I notice the fan were running nonstop because someone replace the radiator but didn't install in the ect switch on the bottom so i went to the junkyard and brought the wire and the ect switch. When i plug in it finally turn off but the issue is i waited for 30 minute the fan never came on to the point i can see smoke coming out the radiator cap.
Old 02-09-14, 09:00 PM
310V6
310V6's Avatar
Bad switch? Was is a used switch? I have testing procedures if you need them.
Old 02-09-14, 11:25 PM
Dvinhie
Dvinhie's Avatar
i got the testing procedure i think and i believe i already test all of it. I'm just wondering what can be wrong with it since the relay/thermostat/ect switch are all working fine...
i don't know if im going to far with this but is there any chance water pump or power steering have anything to do with it?
Old 02-10-14, 06:56 AM
310V6
310V6's Avatar
So if you unplug the ECTS the fans turn on?
Old 02-10-14, 03:00 PM
Dvinhie
Dvinhie's Avatar
Yes if i unplug the bottom ect switch wire then the fan will be running nonstop.
Old 02-10-14, 03:48 PM
310V6
310V6's Avatar
Gotta recheck that switch man. Like you mentioned earlier, maybe the pump isn't pumping.
Old 02-10-14, 08:03 PM
mitmaks
mitmaks's Avatar
Check that switch, it has to actually "switch" at certain temp.
Old 02-17-14, 01:02 AM
Dvinhie
Dvinhie's Avatar
Which switch ? There like four switch. On left side there two more switch is there something to do with that? I research it could be the steering pump connector? Where would that harness be?
damiendada
07-25-13 05:41 AM
Glock20C
GS - 1st Gen (1993-1997)
03-03-13 11:43 AM
Y0UNGLEXUS
11-20-11 09:22 AM
ozzie
11-18-08 05:47 PM
blue_dlb
Maintenance
06-29-05 07:01 PM
Quick Reply: Help fan not turning on
