(DIY) 02 ES300 License Plate Bulbs
Old 03-02-10, 05:16 AM
Mp0wer
Mp0wer's Avatar
Default (DIY) 02 ES300 License Plate Bulbs
If anyone is looking to replace their license plate bulbs in a 2002 ES300.
First pull off these black plugs, just pull the 3 along the front.
Then you have to remove the emergency trunk handle, you need to take apart the handle itself, like this
Then remove the handle by using a screw driver seen here
There are 2 more clips holding the trunk mat
Here you can see the license plate sockets, just turn clockwise
Then replace with a 194 LED bulb or whatever you like
Goodluck
Old 03-02-10, 03:55 PM
eyezack87
Camry ConeKiller
eyezack87's Avatar
Nice. Much simpler than the 2ES. I have to take out the entire tail light to do mine lol...
Old 03-02-10, 05:57 PM
QuachmanES
QuachmanES's Avatar
Is it not possible to access it from the outside?
I just recently switched my license plate lights with LED's on my 3ES, and it was simple to access from the outside. There was 1 small 2-piece plugs for each of the lights. Just push in the middle and pull out the plug, and gently pry out the assembly with a flathead. It should pop out fairly easily, turn to unplug the bulb, and replace.
Took about 5 minutes without having to take apart the inside of the trunk.
Old 03-03-10, 03:38 AM
Mp0wer
Mp0wer's Avatar
I really don't think there is a way to access these bulbs from the outside. If anyone has replaced these bulbs from the outside please let me know. It took me 5 mins to access these bulbs from the inside.
Old 03-03-10, 01:14 PM
hoonami
hoonami's Avatar
when i had my 02 es300, i believe it changed the bulbs from the outside as well... no tools needed, all i had to do was push one pin and it slides out....
Old 03-03-10, 05:55 PM
R1R
R1R's Avatar
Yup, I changed mine from the outside as well. Very easy to do.
Old 09-26-12, 09:39 PM
wdlugitch
wdlugitch's Avatar
My left license plate bulb is out, I bought new bulbs, but do not see any pin to push in and slide it out. Could anyone post a picture of what you are speaking of? Thanks.
Last edited by wdlugitch; 09-26-12 at 09:55 PM. Reason: I realized the person I quoted no longer has the car.
Old 09-27-12, 04:46 AM
speedkar9
speedkar9's Avatar
The method stated above is correct. You need to remove the trunk liner to access the license plate bulbs. There is no external way to change the bulbs on the 4ES.
Old 09-27-12, 10:30 PM
wdlugitch
wdlugitch's Avatar
Thank you. 4ES is 4th generation? You are referring to my 2002? QUOTE=speedkar9;7508737]The method stated above is correct. You need to remove the trunk liner to access the license plate bulbs. There is no external way to change the bulbs on the 4ES.[/QUOTE]
Old 09-28-12, 04:51 AM
speedkar9
speedkar9's Avatar
Yes 2002-06 = 4th gen. Thats how I did my 05, same body style.
Old 10-01-12, 09:24 AM
Andrew211
Andrew211's Avatar
Thanks!!! I'm doing mine today!!
Old 10-01-12, 07:06 PM
speedkar9
speedkar9's Avatar
Old 10-25-12, 10:41 AM
toytrain13
toytrain13's Avatar
I don't see how to disassemble the emergency trunk handle. Do the two halves just snap apart? And is there then a screw to unfasten to remove the rest of the handle?
Old 10-25-12, 07:09 PM
speedkar9
speedkar9's Avatar
Use a thin screw driver to snap the top half away from the bottom half of the handle.
There is no screw behind the handle, just pull it down (hard) and it will come free from the trunk lid.
Old 01-20-13, 09:06 AM
rlx101
rlx101's Avatar
those who replace plate light with super bright LED's - i dont understand why you would want to make it easier for everybody (cops included) to read your plate number??? its like running around and screaming your address and phone number to a bunch of strangers. I am the opposite - i put those tinted plate covers on, had to take them off for the inspection though. cops hat those though.
Quick Reply: (DIY) 02 ES300 License Plate Bulbs
