1997 steering wheel vibration between 55 -70 mph along with oscillating howling sound
Old 12-09-13, 02:01 PM
dlamb89
dlamb89's Avatar
Default 1997 steering wheel vibration between 55 -70 mph along with oscillating howling sound
When I hit just about 55 mph, I notice ONLY my steering wheel starting to vibrate. It isn't intense, just borderline annoying and worth the concern. What's strange is that it doesn't always happen whenever I hit 55, and also does not stay consistent within a single instance. For example, for about 5 seconds this will happen while in the 55-70 range, and it will randomly cease to vibrate, then randomly begins.
The other part here is the howling sound. It is always oscillating,(about 2 short "howls" per second), and I don't really hear it until I hit the 50s. With or without throttle, it happens .
I know there is an exhaust leak right around my drivers seat, could that be considerable for the howling as well? Personally I don't, because the sound always oscillates
EDIT: The howling sound is audible as low as 35/40 mph
Old 12-09-13, 02:58 PM
tomf
tomf's Avatar
The howling indicates to me that a wheel bearing is starting to go bad. Also could be a defective tire. From where is the howling coming?
Old 12-09-13, 03:21 PM
try714
try714's Avatar
Yup change the tires it happen to me rotate it.
Old 12-09-13, 03:29 PM
PuReChaos
PuReChaos's Avatar
Steering wheel vibration could possibly be coming from wheels needing to be balanced.
Old 12-09-13, 06:39 PM
dlamb89
dlamb89's Avatar
Tomf: not sure about where, but it definitely feels like its one of the front wheels. Also makes sense cause its FWD, I take it? I also feel the vibration of the howling under my feet.
When you guys say wheel balancing ,is that the offset distance of the wheel on the axle, or tire pressure, etc? And how would the cost look?
Wheel bearing is also something my friend said might be the issue
Old 12-09-13, 06:50 PM
faithmkss
faithmkss's Avatar
Howling is a strong indication of wheel bearing. Hard to tell without taking everything apart, but if you take your foot and push on the tire as if you are checking to see if it has enough air, the tire could have some play in it. That was the case for me. And typically when one side goes out, so does the other. As a side note, dont just swap out the bearing like I did... (backyard mechanic) we put bearings on bad spindles and guess what, bad bearings a month later. Just my experience.
Old 12-09-13, 07:08 PM
dlamb89
dlamb89's Avatar
Thank you all so much for your Two cents. Does the tire have to be off the ground in order for me to test it?
Old 12-09-13, 08:26 PM
PuReChaos
PuReChaos's Avatar
Wheel balancing is when you add weights to each side of the wheel so that the center of gravity will be the middle of the wheel . Unfortunately its not something you would be able to do yourself as it requires an expensive machine. A tire shop would be able to do it and the ones around me do it for free when you pay them to rotate the tires, however, make sure to mention to them that they need to be balanced. Always a pain to pay a shop for something you know you can do at home (rotating tires).
As an extra note, unbalanced wheels can cause some suspension parts to wear prematurely and also uneven tire wear patterns.
Last edited by PuReChaos; 12-10-13 at 12:25 PM. Reason: correcting definition thanks to tomf
Old 12-09-13, 08:39 PM
dlamb89
dlamb89's Avatar
Excellent advice, thanks a bunch once again. Definitely will be getting the spindles and wheel bearings checked.
So, besides wheel balancing and checking the bearings and spindles, would there be anything else you would recommend to check?
Old 12-10-13, 06:38 AM
PFB
PFB's Avatar
Just a heads up.
1) If you also feel the vibration in your seat, than its most likely the rear wheels, and not the front heels.
2) A bad bearing usually sounds somewhat like a jet engine noise.
Phil
Old 12-10-13, 10:11 AM
tomf
tomf's Avatar
Originally Posted by PuReChaos
Wheel balancing is when you add weights to a wheel to make each wheel equal to each other.
As written, this is not correct. Each wheel is balanced independent of the other wheels. If one side of a wheel is heavier than the other side, it is unbalanced. The center of gravity of the wheel is not at the center of the wheel. An unbalanced wheel, when rotating, will wobble, causing vibration. The faster the rotation the more severe the vibration. Thus weights are added to an unbalanced wheel to balance the wheel so the center of gravity is at the center of the wheel.
BTW it is possible to balance the wheels yourself using a relatively inexpensive tool like this
http://www.amazon.com/Portable-Wheel-Balancer-Bubble-Bullseye/dp/B004JKRO3I/ref=cm_cr_pr_product_top http://www.amazon.com/Portable-Wheel-Balancer-Bubble-Bullseye/dp/B004JKRO3I/ref=cm_cr_pr_product_top
, called a bubble balancer. But I agree with PuReChaos, it is better to have it balanced professionally.
Old 12-10-13, 10:30 AM
tomf
tomf's Avatar
Just so you understand. The spindle Faithmkss mentioned is an integral part of the hub. So when Faithmkss said replace the bearings and the spindle, he meant replace the bearings and the hub.
On the ES300, the front bearings are pressed into the steering knuckle using several tons of force. Then the spindle portion of the hub is pressed into the bearings using several tons of force. Here's an example of a hub and bearing http://www.rockauto.com/catalog/more...741&cc=1387054 .
On the rear the bearings and hub come as an assembly and are are just bolted on. Much simpler to replace. http://www.rockauto.com/catalog/more...338&cc=1387054
Last edited by tomf; 12-10-13 at 10:34 AM. Reason: fixed spelling and syntax errors
Old 12-10-13, 11:53 AM
dlamb89
dlamb89's Avatar
Again, thank you all for your amazing insight. How costly can the process of pressing the front bearings into the steering knuckle be? And hopefully they are the bearings in the back instead of the front.
Update: Found out the front tires are two different brands, great.
So I will have my buddy at the shop check the center weight of each wheel, check the bearings, hubs, and either replace or match the tires. I also have an.ODB II scanner on the way, can't wait to never be potentially lied to again, or having to wait days until I know what's wrong with my baby.
Old 12-10-13, 06:15 PM
ErikTheRed
ErikTheRed's Avatar
I had the same thing you are getting, it turned out to be a locked brake caliper. It was making just enough contact that it would heat and swell at higher speeds (60+) giving the exact sypmtoms you are getting. I would suggest getting them looked at whiel you are checking out the other, but an easy indicator.. once it starts, pull off the road and check you rotor for excessive heat on one side .
------ DO NOT TOUCH THE ROTORS !!!! -----
You should be able to feel the difference from a few inches away. It may also smell strange, metallic smell.
Old 12-10-13, 06:44 PM
dlamb89
dlamb89's Avatar
Thanks Erik. When you say the symptoms were the same as mine, are you talking about the steering wheel vibration, the howling sound, or both?
Is a locked brake caliper the same as a "sticky" caliper?
Next time I get a chance to do 60, and pull over right after, I will definitely check it out.
Quick Reply: 1997 steering wheel vibration between 55 -70 mph along with oscillating howling sound
