Driver side mirror
Old 12-06-13, 01:05 PM
lnguyen12
lnguyen12's Avatar
Default Driver side mirror
Hi all,
The driver side mirror of my 2000 Lexus ES300 got stolen. It costs $500.00 (if buy from Lexus dealer) to replace it. I wonder if there is a less expensive one somewhere I could purchase, and could I install it by myself.
I appreciate receiving your advice.
Thanks
LeeLee
Old 12-06-13, 01:15 PM
PFB
PFB's Avatar
Short of making an Insurance claim, I believe your only other option apart from the dealer is one from a scrap yard
Old 12-06-13, 01:22 PM
hypervish
hypervish's Avatar
Welcome to Club Lexus!
Get a used one from ebay or a salvage yard.
You can use www.car-part.com to search which salvage yards have one in stock near you.
Old 12-06-13, 02:24 PM
01LEXPL
01LEXPL's Avatar
Used ones, complete are around 100-150$
Old 12-09-13, 08:06 PM
Power6
Power6's Avatar
make sure you look at pictures before you buy, You want the glass to look clear and not splotchy so you know the auto-dim is intact. EBay is good for this, and the sellers don't know these cars had a dimming mirror so the price is not bad. Buy one that is good condition and the color of your car, not worth repainting so buy the right one.
I have two matching spares in the basement, mostly for when the dimming glass goes. Just do not EVER test the dimming mirror function by hooking the wires directly to a power source off the car...burned a spare glass on that.
Old 12-16-13, 07:28 PM
lnguyen12
lnguyen12's Avatar
Thank you for the information everyone. Once I buy this part, will I be able to remove just the backing plate and mirror to place in my driver side housing by myself? I don't want to go through the trouble of replacing the entire housing and having to repaint it.
Old 12-17-13, 01:02 PM
try714
try714's Avatar
I might have one for sale? But in gold color.
Old 12-23-13, 06:48 AM
Power6
Power6's Avatar
When you said stolen mirror I thought you meant the whole thing!
If it is only the glass, yes you can snap the new one right in. Make sure nothing was broken by the thieves stealing your mirror glass though...
To remove the glass from the used mirror, you push the top in so the glass is adjusted all the way "up" then you can get a screwdriver tip into the bottom slots to release the tabs. Then you tip the glass up and pull the top tabs out. Take your time till you feel out how it works. The below is for a Subaru but the procedure is the same except for the heat/dim wiring (on the ES it unplugs from insdie the mirror housing and is a real PITA to get unplugged)
Old 05-01-14, 09:32 AM
bwb
bwb's Avatar
Late entry, but had same issues and thought I would add to the thread
I usually just lurk vs, post as it's my daughters car.
Lexus part number is 8793133190 for passenger side.mirror replacement only. Not sure of drivers side.
Ordered a new, oem from Lexus of South Atlanta for 69.80 + shipping.
Hope this helps someone.
2000 ES300
Old 05-01-14, 12:05 PM
Power6
Power6's Avatar
Good info, the passengers glass will be cheap. The 00-01 cars have a dimming driver's side mirror, which is a few hundred $$ new, so best off buying that used. I have gotten whole used mirrors just to have a spare dimming glass for $50.
yvjoshi
01-24-17 06:44 PM
sl227
12-17-13 09:53 AM
DjRadical3
Performance & Maintenance
12-03-12 05:15 PM
rx300mm
ES - 5th Gen (2007-2012)
03-04-11 12:33 PM
Quick Reply: Driver side mirror
