Go Back   Club Lexus Forums > Lexus Model Forums > ES Models > ES300 and ES330
Sign in using an external account
Register Forgot Password?
headlight auto leveling
Thread Tools Search this Thread Display Modes
Old 10-24-13, 09:39 PM   #1
jakebot88
Trader Score: (0)
jakebot88's Avatar
Default headlight auto leveling
I just put new shocks and wheels/tires on my car and i noticed that my headlights to seem to point as far up as they used to. it seems like they virtually point right at the ground... or so it seems.
I don't have any lights on the dash or anything. I was just wondering what you guys think. I live out in the country and need my brights so I don't hit deer. Thanks.
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
jakebot88 is offline   Reply With Quote
Old 10-25-13, 08:52 AM   #2
PFB
Trader Score: (0)
PFB's Avatar
The leveling mechanism is located on the right rear side of the car (passenger side) close to the right back wheel. Have a look in that area, you may have dislodged or bent something while you were doing the work.
Phil
PFB is offline   Reply With Quote
Old 10-27-13, 03:52 PM   #3
jakebot88
Trader Score: (0)
jakebot88's Avatar
Oh really hmmmm. I can have a look. Do you know exactly what it looks like or where it is? Or can you point me in the direction of where to find that information? Thanks.
Old 10-27-13, 04:56 PM   #4
PFB
Trader Score: (0)
PFB's Avatar
I havent looked at it for awaile' but it's a vertical mechanical lever, located roughly between the back two wheels, but much closer to the right back wheel. A bt to the left of the rear spring.
It probably has an electrical wire coming out of It.
Phil
Old 10-27-13, 05:01 PM   #5
PFB
Trader Score: (0)
PFB's Avatar
I havent looked at it for awhile, so I'm going by memory, but it's a vertical mechanical rod about 5" high, mounted on the right rear lower swing arm, A bt to the left of the rear right wheel
It has an electrical wire attached.
Phil
Old 10-27-13, 05:08 PM   #6
imherenow
Trader Score: (0)
imherenow's Avatar
what could have happened is that while you were changing the suspension ( prolly changed the back i assume) the automatic headlight sensor leveling could have be changed. it happens. Here is the pic of the sensor :
What i suggest is you can go ahead and change the headlight level located in the back of the main headlamp housing. the pic had 2 nuts ( not sure what size) .One for high and one for low beam . However in my case i only have one nut( weird).
Any case go ahead and adjust either clockwise or counter-clockwise
Also i suggest you make sure have battery booster incase the battery dies because you will have turn the headlight on. Or engine running should be fine.
I my case i have removed that rod you see or the strut that tells the sensor the height of the car. Because mine was making noise and was well broken. the dealer doesnt just has that part instead you will have buy the entire sensor too..which is super$$$. so right now i dont have that rod but my lights still work and no error on the dash panel
__________________
imherenow is offline   Reply With Quote
Old 11-05-13, 06:22 PM   #7
jakebot88
Trader Score: (0)
jakebot88's Avatar
I had my buddy check the leveling stuff in the back and everything looks good and is hooked up snug. I just think they're pointed too low. So i'm going to aim them up a little. thanks guys!
Similar Threads
Thread Thread Starter Forum Replies Last Post
Can HeadLights manually be moved????? I don't want to goto the dealership.... rclab1 SC 430 24 07-29-14 09:10 PM
Defective Headlight? Can't raise my low beam Vibes63 IS - Second Generation 13 09-09-13 10:55 PM
Just put in new headlights and fogs, aiming question. talbott GS - Second Generation 7 04-28-13 02:57 PM
Headlights Adjustment sensor reset, is it possible? WeisISF IS - Second Generation 10 09-13-12 10:17 PM
Changing the headlight bulb khuezee IS - Second Generation 3 08-08-11 05:06 PM
Tags
200, 2008, 300, arm, auto, autoleveling, es, es300, head, headlight, leveling, lexus, light
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join ClubLexus
Copyright © 2000-2008 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
Get all contact info
