Newbie with 2000 es300 with flickering engine lights
Old 08-15-13, 08:36 PM
Bayliner
Bayliner's Avatar
Default Newbie with 2000 es300 with flickering engine lights
2000 es300 with 250,000 miles and in great condition
Sluggish engine turn over when starting
All lights are dim until rpms come up
When I turn on headlights and A/C the clock and gear indicator lights as well as seatbelt or any other of those type of lights begin to flicker
Web the flickering happens, it shifts strange. At a slightly higher rpm than normal and acts indecisive about going into gear. Like a quick "in out in"
Transmission has 125,000 miles on it
What's wrong?
Old 08-15-13, 08:53 PM
PFB
PFB's Avatar
Start by checking your Battery, and Alternator charging voltage.
Phil
Old 08-15-13, 09:05 PM
Bayliner
Bayliner's Avatar
11-12 volts when not running
12-13 volts while running
Battery is old. Guess it could hold proper voltage but can't pass ampage,
Would a dying battery affect shifting?
Old 08-15-13, 09:27 PM
PFB
PFB's Avatar
Your voltages are too low.
A dying battery, and/or low charging voltage could effect, amongst others, the engine and transmission management systems, and computers. This can cause the symptoms that you described.
Phil
Old 08-16-13, 09:21 AM
Bayliner
Bayliner's Avatar
Charged battery all night and it ran fine. How do I confirm if the problem is with the battery or the alternator?
Old 08-16-13, 09:37 AM
PFB
PFB's Avatar
Im not sure if youre in Canada or California, but if you're California than any Autozone will check your charging system free of charge. If you're in Canada, than any garage is equipped to do it, but they'll charge you for it.
If you're in Canada and your Battery is more than 4 years old, you might as well change it without testing it. Best place to get them is from Costco. Their batteries are excellent, and there is a no questions asked 5 years money back/exchange warranty. ( could be 3 years, can't remember)
Should. Cost less than $80 CDN, and you can change it yourself in a few minutes.
Phil
Old 08-16-13, 10:04 AM
Bayliner
Bayliner's Avatar
Not a Canuck, I'm in northern Cali, auto zone will bench test rite? Or will they test it while in a running car?
Old 08-16-13, 10:30 AM
PFB
PFB's Avatar
They'll come out to your car, with their specialized equipment and test your complete charging system (battery and Alternator) free of charge. Car will be running.
Can't beat that
Phil
Old 08-16-13, 05:04 PM
Bayliner
Bayliner's Avatar
They said voltage regulator is bad and possibly the battery too! Any step by steps out there for replacing this?
Old 08-16-13, 07:04 PM
PFB
PFB's Avatar
How old is your battery?
Old 08-17-13, 07:32 PM
Bayliner
Bayliner's Avatar
Had alternator tested. Voltage regulator is bad. Im changing it myself. Can anyone tell me how to release tension on the belt?
Old 08-17-13, 09:07 PM
Bayliner
Bayliner's Avatar
Guess I'm answering all my own questions today. Found tensioner rigged up on alternator. Last time it was changed they must have used a pry bar to tension it and tightened it in place. Broke a mounting bolt in the process. I will report if my problems go away tomorrow. Rusty bolts on San Francisco cars are a *****
dahvbrooto
11-30-18 08:05 PM
Leastimson
11-10-16 08:59 AM
noquarter
12-17-12 02:31 PM
amblyn
RX - 1st Gen (1999-2003)
01-23-12 08:22 PM
TURBO300RX
11-30-06 06:38 AM
Quick Reply: Newbie with 2000 es300 with flickering engine lights
