the dreaded P0441 code
Old 03-30-15, 06:51 PM
1960vw
1960vw's Avatar
Also found that the fuel pump gasket was bad, access through rear panel under rear seat.
Old 04-06-15, 04:36 PM
vishesh
vishesh's Avatar
Default How/where to find the overflow hose?
Where is the overflow hose / where can I get access to it to purge? After a bit of research, the discussions I am finding of "overflow hose" refer to the engine coolant system, not the fuel supply.
Originally Posted by 1960vw
Hey Myth, sorry took so long to post but your idea worked! Purged that overflow hose soon after your post , cleared codes and now no more light! Thanks bunches for the tip !!!
Old 04-06-15, 06:42 PM
DRACO A5OG
DRACO A5OG's Avatar
When you open the fuel cap you will see 2 small holes. When gas is over filled, fuel gets into those holes. the theory is with enough over fills and dirt will clog the over flow hoses and develop a fault in the evap system ergo improper flow.
I used compressed air and a blower fitting and blew air thru mine. Unfortunately that was not the issue with my P0441 CEL
Old 04-06-15, 09:58 PM
vishesh
vishesh's Avatar
Thanks! Will give it a shot and report back.
Old 04-08-15, 07:18 PM
vishesh
vishesh's Avatar
I used one of those canisters of compressed air (the kind you use to dust off your computer keyboard) and cleared out the the two holes leading to the overflow purge lines.
This is a pretty accurate description of what it should sound like when overflow lines are cleared:
Run a compressor air hose in the small hole in your filler neck. I just use an air blower with a push button on/off for a about a minute. You should hear a sound change from stuffy to open loose air, thats what sounded like to me.
Sounds like air whooshing through a metallic pipe.
Reset/cleared the P0441 and P0446 CEL / DTCs and they haven't come back yet. I suspect (hope) this was the source of the CEL / DTCs because I very recently topped off my gas tank, then got the P0441 + P0446.
Thanks all!
Old 09-12-18, 08:06 PM
Eugene1997
Eugene1997's Avatar
Default P0441 code
Good idea Myth! I'll give it a try.
Hey you mentioned blowing out a line if you happened to overfill the tank. I’ve tried to check on all the issues but don’t have any luck. Can you maybe give me a point in the direction of where this hose is that I need to blow out? Thanks!!
Old 03-08-19, 08:22 PM
Sin1UZFE
Sin1UZFE's Avatar
I think I need to replace this
Old 02-20-20, 06:36 AM
gw204
gw204's Avatar
Going to try this on my '01 that's currently throwing a P0441. Did you disconnect the hoses before blowing out the lines?
GrnEyeDog
06-19-17 12:49 PM
boatguy57
Maintenance
04-20-17 05:18 AM
Patrickleo
06-27-16 09:42 AM
JAB
RX - 1st Gen (1999-2003)
15
07-07-11 10:13 AM
LudeNsoL
08-05-09 12:18 AM
Quick Reply: the dreaded P0441 code
