Ignition Coil Connector Clips
Evening Everyone,
I am about to do a overdue tune up on my girlfriends 97 ES300 and I already purchased the spark plugs, fuel filter, o2 sensor and an upper motor mount.
Only problem that I am having is the Ignition Coil Connector Clips, I know then you remove these to take out the coil's the clip will typically break more often then not, I have not been able to find this ANYWHERE! Autozone, Pep Boys, Strauss Auto, O'Reilly etc etc.
Even the local Lexus and Toyota parts department have been unsuccessful (or lazy) in locating this part. And since I don't have an OEM Part Number they usually give me 5 min or so and just say they don't have them in stock.
Does ANYONE know where I can get these so I can get her car fixed, clear the codes and get her car inspected.
Thank You.
Thank You.
Okay, found an answer for you, as I had the same issue.
https://www.clublexus.com/forums/es3...need-part.html
okay, found an answer for you, as i had the same issue.
Pnuge88
09-16-17 06:34 AM
Weapon F
IS F (2008-2014)
09-13-16 09:35 AM
