Go Back   Club Lexus Forums > Lexus Model Forums > ES Models > ES300 and ES330
Sign in using an external account
Register Forgot Password?
2005 es330 front and rear caliper toque spec's
Thread Tools Search this Thread Display Modes
Old 06-27-13, 02:31 PM   #1
SGLexus
Trader Score: (0)
Default 2005 es330 front and rear caliper toque spec's
Hey guys i was doing a brake job on my es and was wanting to make sure i had the right torque spec's for the rear caliper bracket and slide and also the front caliper bracket and slides
Thanks
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
SGLexus is offline   Reply With Quote
Old 06-27-13, 03:02 PM   #2
KLF
Trader Score: (0)
KLF's Avatar
Fronts: The bolts that go into the slide pins get 25 ft-lbs. The bolts for the caliper brackets get 79 ft-lbs.
Rears: The slide pin bolts get 25 ft-lbs. The bolts for the caliper brackets get 46 ft-lbs.
__________________
'98 ES300 (Sold, but not forgotten)
'05 ES330 (replacement for above) - Nav, ML, 17's.
'04 Toyota Highlander (RX330 wannabe)
'87 Toyota Xcab pickup - totally restored, highly modified, daily driver
KLF is offline   Reply With Quote
Old 06-27-13, 03:27 PM   #3
SGLexus
Trader Score: (0)
Alright thanks
Old 06-27-13, 04:36 PM   #4
SGLexus
Trader Score: (0)
Default 2005 Lexus ES330
Well while loosening the rear slide bolt and the Bolt snapped in side the hole and now we were so close and stumped. Really feeling bad. The caliper bracket bolt is stripped and don't know where to get the part .
Old 06-28-13, 09:04 AM   #5
SGLexus
Trader Score: (0)
Default Where could I get the rear caliper bolt?
Anyone have an idea of where I can get the rear caliper bolt?
Old 06-28-13, 12:09 PM   #6
KLF
Trader Score: (0)
KLF's Avatar
Part #90119-10379
That is a special application hardened bolt, dealer only. List price is only $1.34.
__________________
Old 06-28-13, 01:04 PM   #7
SGLexus
Trader Score: (0)
hey thanks LKF! So does that mean only the dealer can install it? I need to get that small part of the bolt out that stuck in when it stripped tomorrow.
Old 06-28-13, 01:46 PM   #8
KLF
Trader Score: (0)
KLF's Avatar
Quote:
No just that I would only buy that from Toyota or Lexus. Not from a hardware store.
Posted from ClubLexus.com App for Android
__________________
Similar Threads
Thread Thread Starter Forum Replies Last Post
Torque Spec. j.tom ES350 (2007 - 2012) 13 07-03-14 11:11 AM
Caliper Bolt Torque Spec kee0419 SC 430 2 09-29-12 03:33 PM
Ceased Calipers BernieIS Suspension and Brakes 3 02-21-12 12:24 PM
Caliper Mounting Bracket Bolt Torque Spec? tuxlexus RX - First Generation 2 03-26-07 03:31 PM
Brake torque specs needed fstepanov ES300 and ES330 3 09-22-05 06:25 AM
Tags
2005, 2006, 330, assembly, bolt, brakes, caliper, es, es330, front, highlander, lexus, pin, rear, slide, toque, torque, toyota
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join ClubLexus
Copyright © 2000-2015 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
Get all contact info
