P0401 - EGR flow insufficient on ES300 "97+
Old 06-16-13, 02:00 PM
ibuddler
ibuddler's Avatar
Originally Posted by GS4_Fiend
You can safely isolate the EGR valve and the EGR passages. The culprit is either the modulator or the EGR VSV. But most likely it's the modulator.
Well, I read the service manual today. But I can't find the modulator on the 97 ES. Can anyone tell me where is it?
Old 06-17-13, 12:20 PM
GS4_Fiend
GS4_Fiend's Avatar
should be right next to the EGR.
Old 06-17-13, 03:41 PM
ibuddler
ibuddler's Avatar
Would you mind to take a picture for me please? I've got nothing near my EGR and my baby is 98ES300. Thanks.
Old 06-18-13, 10:13 AM
GS4_Fiend
GS4_Fiend's Avatar
take a picture of your engine and i will show you
Old 06-20-13, 08:57 AM
ibuddler
ibuddler's Avatar
It's pretty dirty. Haven't washed my engine for years.
Old 06-20-13, 09:51 AM
GS4_Fiend
GS4_Fiend's Avatar
Ok. Your car doesn't have an EGR modulator, it has a vacuum check valve instead. The EGR VSV is the one that controls the vacuum flow to the vacuum check valve and this valve passes vacuum to the EGR.
The VCV is purple and you need to remove the engine cover. Get a vacuum pump, pump the middle port and plug the outer port and vacuum should hold around 4.4 - 7.1 in Hg. If it doesn't vacuum check valve needs to be replaced.
Old 06-20-13, 11:10 AM
ibuddler
ibuddler's Avatar
Oops. Sounds like a lot of work. Which valve do I need to replace? VCV or VSV? What does it look like? I'll take off the engine cover tonight and take a picture. Could you point it out tomorrow? Thanks.
Old 06-21-13, 11:13 AM
GS4_Fiend
GS4_Fiend's Avatar
Just follow the vacuum line from the EGR that goes to the VCV which is purple. And test it first as i stated.
Old 07-02-13, 02:12 PM
ibuddler
ibuddler's Avatar
Sorry. I uploaded the wrong picture. Here you go.
Old 07-02-13, 02:18 PM
ibuddler
ibuddler's Avatar
So basically I have to take the purple one out and vacuum the middle port and measure the pressure at the outer port? Do you know the PN for this part? I might just replace it instead of take it to the dealer for the measurement. I don't have tools at home.
Old 07-02-13, 02:22 PM
ibuddler
ibuddler's Avatar
To be more precisely, are the middle and out ports as I circled in the picture? Do you also think it might be the problem coming from the sensor on the EGR Valve?
Old 07-09-13, 11:09 AM
ibuddler
ibuddler's Avatar
pump for help
Old 12-25-13, 08:16 PM
vdubill
vdubill's Avatar
Did you ever get this fixed?
Old 12-30-13, 08:18 AM
ibuddler
ibuddler's Avatar
No, I'm just too lazy and it doesn't seem to affect anything except there's CEL on all the time.
I guess I'm gonna leave it as is.
someES300
05-02-14 03:33 AM
mjbtn
13
10-17-12 08:43 PM
mitmaks
04-17-12 05:14 PM
mpringle
06-05-09 06:52 PM
Quick Reply: P0401 - EGR flow insufficient on ES300 "97+
