Best place to ground amp 1997 ES 300
I currently have a 4 channel amp, and also a mono amp. I have them installed already and they work, but there is a lot of sound coming through the speakers which I am guessing is from a bad ground. Where is the best location to ground out amps in the trunk area ? Thanks !
Also....where could I find a higher performance alternator that wont cost a fortune ?
Not sure if the 1997 is compatible but I know that the Highlander had a more powerful alternator that shared the bolt pattern as some years of the ES. Don't ask me for specifics though.
Hope it helps put you on the right track.
KahnBB6
11-08-11 07:07 AM
