Help thicker head gasket
Old 05-21-13, 10:53 AM
Quadcam
Quadcam's Avatar
Default Help thicker head gasket
Who sells them I need a shim our head gasket 0.008 thicker
Thanks
Old 05-21-13, 06:36 PM
Bdub215
Bdub215's Avatar
what motor?
Old 05-21-13, 08:22 PM
EEngineer
EEngineer's Avatar
no such thing for our cars. your heads are done for
Old 05-22-13, 07:33 AM
Ebp609si
Ebp609si's Avatar
My advice, if its because of the heads you can pick up a spare motor from a local scrap yard and freshen it up a bit before swapping heads or motors
Old 05-22-13, 07:34 AM
PFB
PFB's Avatar
If you do a web search you will find many places that can make you a custom head gasket at a reasonable price.
What happened to the car?
Phil
Old 05-22-13, 08:14 AM
DGIKULJOT
DGIKULJOT's Avatar
http://www.ebay.com/itm/ROCK-PRODUCTS-HS960L-Cylinder-Head-Shim-Gasket-/121107959616?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3ALexus%7CModel%3AES300&hash=item1c3298cf40&vxp=mtr
Won't something like that work? All over ebay
Old 05-22-13, 11:53 PM
Quadcam
Quadcam's Avatar
Default 3vzfe
Originally Posted by Bdub215
what motor?
3vzfe 92 es300
Old 05-22-13, 11:57 PM
Quadcam
Quadcam's Avatar
That's a junk yard head I bought a set because mine got well let's just say the valve springs turned blue from heat
So one head from the j/k yard fine (within specs) the rear head has already been shaved 0.008 ......po
And the j/k is fresh out of heads
Old 05-22-13, 11:59 PM
Quadcam
Quadcam's Avatar
Originally Posted by DGIKULJOT
Rock Products HS960L Cylinder Head Shim Gasket | eBay
Yes but I'm having a hard time finding one thinner than 0.020 thickness
Aesthetikz
GS - 1st Gen (1993-1997)
08-30-16 11:58 AM
supraclay
Performance & Maintenance
01-30-12 07:12 PM
VSsc400
SC- 1st Gen (1992-2000)
09-02-02 10:46 PM
Quick Reply: Help thicker head gasket
