Air Conditioner Filter
Old 05-08-13, 02:29 AM
artbuc
artbuc's Avatar
Default Air Conditioner Filter
Helping a friend maintain her 03 ES300. OM says certain models are equipped with an AC filter. How do I know if her car has one? Call dealer with the VIN? Is the AC filter the same as the cabin air filter? The OM does not mention a cabin air filter. I had a 95 LS400 and 99 RX300. Both had cabin air filters behind the glove box. Thanks.
Old 05-08-13, 03:37 AM
hypervish
hypervish's Avatar
Yes, the AC filter is the same as the cabin air filter. Standard on all ES models of this year. It's located right behind the glovebox.
Old 05-08-13, 03:49 AM
artbuc
artbuc's Avatar
Thanks. Yes I just removed it. Looks original but not too dirty. In my experience, cabin air filters last the lifetime of the car. Give them a good vacuum and they are good to go.I do not believe the little bit of charcoal does much to eliminate odors.
Old 05-08-13, 11:08 AM
hypervish
hypervish's Avatar
You're welcome!
I try and vacuum clean mine every year, and then will generally replace every other year. It isn't necessary to clean it as much as I do, but it's just one more excuse for me to work on the car!
Old 07-28-13, 05:10 PM
pauloil
pauloil's Avatar
when you take the screw off the end of the piston,also remove the arm of the piston from the lid. if the piston comes off and falls down, it just snaps back into place using one of the plastic holes on the bottom of piston. upon removal, pay attention to the orientation of the pins so you know how to reinstall. I used 87139-YZZ05 in my 05 ES
MNRambler
08-02-15 11:05 AM
triplecore
Maintenance
11-17-08 03:58 PM
prep2
19
04-11-06 05:59 PM
Woogie
06-28-05 11:32 AM
Quick Reply: Air Conditioner Filter
