Rough idle, no brake pedal movement
So I have a 2000 es300.
Only 87k on it, was driving and got a rough idle along with exhaust smell in cabin, cel and trac off lights. Timing belt was changed at 53k. I bought the car with 79k and I've changed the oil twice.
I'm getting error codes p0440, p0302, p1354.
I also changed the ocv's first time this occurred and it didn't fix the issue! Anyone got any suggestions?
Maybe your brake booster is bad? Or it could be a vacuum leak going to the booster.
Through the marvels of modern complexity I wouldn't be surprised if the other stuff was somehow related. either way that's my $.02; simple check, simple fix. If not, consider having someone more qualified look at it?
Also, do a search online, not only on this forum either. OBD2 codes are universal and how systems are put together can carry across many different models and brands. Ever notice how almost everyone uses McPherson struts? This could be a common problem on a Ford with a similar layout or something.
Gave in and took it to lexus. They are saying that it is a bad o2 sensor in bank two.
When I say no brake pedal movement I mean when I am under 5 mph or at a stop I cannot depress the pedal and it feels like I have zero brakes.
$240 to fix, could have been worse I guess? Will let you know once I get "pearl" back if its truly fixed this time because replacing the OCV in bank 2 didn't do the trick the first time.
I would check the brake and bleed the fluid to start with as for the brake issue. If you aren't mechanic incline, take it to a local ma&pa shop to get it check rather than Lexus dealership because the price you pay for small one will save you an arm and leg. Keep us posted.
Still not fixed...
Ok, so here we are again. CEL and track off light back on again. Didn't even make it through a full weekend... Going to invest in a code reader at this point... I will let you know what codes I get this time.
What I do know: OCV bank 2 not the problem, it's been replaced. It's not the o2 sensor because that is what lexus just replaced.
Be careful though starter fluid on hot engine can ignite.
DG-
I went back to lexus this morning to have a "conversation" with them. Ran another diagnostic and found that I had a leaking vacuum hose. Anyways, they replaced the hose and didn't charge me a penny this time.
So, to recap, ocv bank 2, o2 sensor, and now vacuum hose. $385 later we'll give it a week and see what happens....
Update
About a month later and car is running great.... I probably spent too much money but its fixed now.... If you have a rough idle, lunging around 40mph @ 1500rpm, with no brake pedal when stopped, check all vacuum hoses before taking it anywhere...:
WhatYaGot
10-16-13 08:30 AM
en11871
04-17-10 05:32 PM
