Need 2002 ES300 Radio Wiring Diagram
Old 04-05-13, 08:41 PM
vanges300
vanges300's Avatar
Default Need 2002 ES300 Radio Wiring Diagram
Hi fellow owners. I bought a new head unit to replace my OEM unit. I have install many system in the past and consider myself semi professional at doing it. I have search through GOOGLE and could not find any wiring diagram for model year 2002 ES300. I can normally find them at the12volts.com but they don't have it either. I thought it would be the wires from connector that connect to the OEM unit. I tried splicing them and tap to test but nothing work. I need help. By the way, I do not have Mark Levington system or Navi. Just the Premium System. Thanks!
Old 04-06-13, 07:01 AM
Kansas
Kansas's Avatar
There seems to be separate diagrams for the single CD and 6-CD standard audio systems. Here are both.
LeX2K (06-02-17)
Old 04-08-13, 08:02 AM
vanges300
vanges300's Avatar
Thank you Kansas. I couldn't wait so I found the location of the stock amplifier and got it to work. Thanks for the reply and help. Hopefully this will help future ES300 when they search for the diagram.
*Note - the stock amp is located behind the glove compartment next to the ECU.
Old 01-12-14, 08:51 AM
Icecarr
Icecarr's Avatar
Default Es 300 with ml wiring
Do you have the one for the ml amp
Old 06-02-17, 03:55 PM
rayservist
rayservist's Avatar
Default 6cd vs 1cd wiring
i have the 6cd version and trying to install aftermark headunit with metra 80-7113 harness. The 6cd harness has no amp on wire, where the 1cd harness does, so where does the amp on wire connect to from the headunit?
Old 04-06-23, 04:15 PM
glenpointe
glenpointe's Avatar
my 2002 base Lexus ES300 6-dsc CD used only one connector, this has two. Do you have the pinout diagram for one connector?
alex brand
Maintenance
04-22-07 09:19 PM
Quick Reply: Need 2002 ES300 Radio Wiring Diagram
