1999 ES300 Mobil 1 synthetic
Old 03-20-13, 01:53 PM
kushdaddy
kushdaddy's Avatar
Default 1999 ES300 Mobil 1 synthetic
Should I use Mobile 1? My car has 147k miles on it. I don't know if the previous owner used synthetic oil.
Old 03-20-13, 02:39 PM
Received 3,036 Likes on 2,550 Posts
It doesn't matter what the previous owner used, what's important is the condition of the various gaskets and seals. Synthetic oil is almost always better than conventional oil but can cause leaks, which will occur if the various seals are in fair to poor condition.
Old 03-20-13, 02:40 PM
PFB
PFB's Avatar
Mobil-1 is an excellent choice. It's never too late to switch to Synthetic. I use the same oil, and the OEM Lexus oil filter. Mobil-1 extended service, has more additives, but is slightly more expensive, and may be overkill.
Just make sure that you buy 5W-30, which is what's specified for your car, and change It, and the filter every 3,000 miles. Walmart usually has the best prices.
Phil
Old 03-20-13, 02:48 PM
PFB
PFB's Avatar
Synthetic oil will not CAUSE leaks, but may magnify existing problems with seals and gaskets. The reason being is that it flows much better than conventional oil, so it may find some places to leak out which conventional oil was just too thick to escape from.
One advantage of Synthetic oils however is that they cause gaskets and seals to swell, so typically after a few thousand miles such leaks just stop.
Phil
Old 03-20-13, 02:55 PM
Originally Posted by PFB
Synthetic oil will not CAUSE leaks..
Semantics. Synthetic oil can get past seals more readily than conventional in some conditions. Better?
Old 03-20-13, 03:01 PM
PFB
PFB's Avatar
If you agree to add ..."past borderline seal" .... Than I'm good with that.
( just goes to show you that I'm not that busy today LOL)
Phil
Old 03-20-13, 03:53 PM
moonphase
moonphase's Avatar
I use Valvoline Max Life, which is much less expensive and is synthetic as well. The filter quality is also important, so I use Wix, or Purolator.
Old 03-21-13, 10:59 AM
PFB
PFB's Avatar
Here is an excellent video on conventional vs. synthetic oil
Phil
Old 03-21-13, 12:38 PM
cephas
cephas's Avatar
I don't usually worry about which type of synthetic oil. Walmart synthetic is about $20, and Quaker State Synthetic is a buck more so I've been using that. I've heard that as long as it has an SAE seal on it, it's all good.
Also use Toyota OEM filters since it's less than $5/ea and they come with a replacement gasket which is nice.
I switched at about 170k and haven't had any leak issues (closing in on 200k in a month or so)
Old 03-21-13, 06:15 PM
01LEXPL
01LEXPL's Avatar
This is a controversy... My ES has 145k, and rear main seal along with the upper oil pan (bottom end seal) sweats and has been since I can recall. I just don't trust changing so late since it will most likely seep further. Even "grey_es300" in another thread mentioned he went from synthetic to semi-blend since it will resolve the leak to a sweat in his es300 with 200k on it. This is my one hold-back thus far. I would do it, but don't want to go there and back...
Old 03-21-13, 07:32 PM
mdbrown
mdbrown's Avatar
My 2000 ES300 has 145k miles on it. I prefer Valvoline high mileage synthetic blend. Works like a champ!
Old 03-22-13, 12:15 AM
Scuba420
Scuba420's Avatar
mobile 1 extended performce says 15k mile oil change its true should change every3k miles if left longer still stays golden its freaky i have 150k miles in my 95 lex es300 and the car doesnt get babied i run down alot of cars its funny ran the new camry v6 down also from a dig and a roll only have intake exhaust 93 octane .. brand new auto tranny oversized all aluminum solara radiator upgraded tranny cooler ..but really the oil stays golden for ever that is the best oil i have ever seen hands down not debaitable lol but for real used in my sr20det made around 500whp on built blacktop 30-33 psi gt30 used royal purple it was like water made a bunch of **** leak .. i have a 500+ whp gto 04 ls1 built auto right now using royal purple only because it came with that oil and i havnt got a chance to change though i am running 10w30 btw in my 1mz-fe mobile 1 extended performce
Old 03-22-13, 05:07 PM
kushdaddy
kushdaddy's Avatar
Okay thanks will switch to synthetic when it time for an oil change
Old 03-22-13, 07:47 PM
maximakid
maximakid's Avatar
WTF?
Old 03-22-13, 08:16 PM
imherenow
imherenow's Avatar
i have 180K and i have stuck with traditional oil and never changed any gaskets and no leaks. Just keep with what ever oil it was originally and keep changing @ correct intervals = you will be fine
Quick Reply: 1999 ES300 Mobil 1 synthetic
