93 ES300 CA smog fail - need suggestions.
Old 02-09-13, 01:12 PM
rjryowit
rjryowit's Avatar
Default 93 ES300 CA smog fail - need suggestions.
New member here. Failed CA smog at low speed. Had local shop who has serviced car for many years look at it. He says no vacuum leaks, cat looks good, but needed plug change.
Went back in today, failed again. Actually little worse score.
Here are my measured results from todays test.
15mph
%co2 14.60
%o2 .02
HC 90 max is 58 (first test 84)
CO .25
NO 0348
25mph
%co2 14.78
%o2 .00
HC 48 max is 48 (first test 48)
CO .08
NO 0085
Any ideas of what to do? All previous smogs I have always passed with room to spare. btw have 235k miles on it.
Old 02-09-13, 01:55 PM
DixonPai
DixonPai's Avatar
Did they let the car warm up before going in to test?
Old 02-09-13, 04:16 PM
rjryowit
rjryowit's Avatar
Yes. I drove it for 30 minutes plus they let it run about 15 minutes before they tested.
Old 02-10-13, 10:56 PM
Mxkmster
Mxkmster's Avatar
Tune ups are a super big deal on these cars. Got to make sure everything is good. Spark plug wires, spark plugs, distribtor cap, pcv valve, and clean and make sure your EGR is working. do you have a picture of your printout from smog
Old 02-19-13, 04:05 PM
lexus4all
lexus4all's Avatar
Don't know if the situation has improved, but drive the car until almost empty. Then put in some fuel injector cleaner (Preferably Chevron with Techron). Drive around a bit more and then fuel up with quality gas.
After that, clean your air filter and try again
Old 02-20-13, 06:55 AM
DGIKULJOT
DGIKULJOT's Avatar
My car which is a 98 Lexus Es300 kept failing smog too. One shop I took it to claimed nothing was wrong except the ecu. I let my neighbors relatives work on it since I was really busy with school at the time. They changed a bunch of stuff such as the intake gasket, MAF (even tho it tested fine for me), intake air temperature sensor and one of the AFR sensors. After that it passed with flying colors. The intake gasket wasn't even obvious so I would look at all that. Especially the Intake temp sensor, if it is bad the car will put in incorrect amounts of fuel thinking the air is colder then it might actually be and such. The AFR sensors are another biggie.
dricacho
SC- 1st Gen (1992-2000)
05-10-15 08:22 PM
droopy128
03-12-14 04:49 PM
kennedy759
03-12-14 05:47 AM
johnblagg
12-29-11 11:56 PM
Dan H
01-03-05 02:58 AM
Quick Reply: 93 ES300 CA smog fail - need suggestions.
