1992 ES300 Acceleration Issues
Old 03-08-13, 01:58 PM
  #31
canucklehe
canucklehe's Avatar
did you replace the filter, or have it done? what was the job like to do? how long/complicated?
how do you check the CAT for flow/blockage?
Old 03-11-13, 08:04 AM
  #32
lexus4all
lexus4all's Avatar
My apologies, I didn't make myself clear. I took it in to do a fuel filter check and if it was the cause, which it was, then replace it. I actually searched the forums for how to do it myself, but it seemed to be easy, but time consuming, and I didn't have much time this weekend so, had them do it.
I don' t know how to check the CAT for flow/blockage, but I am bringing it to the same store when I get more cash. I suppose I could search the forums again, I'm sure I'm not the only one who has had these issues. If I had to guess, I would say we need to connect some device to the O2 Sensor or something.
Old 03-11-13, 04:33 PM
  #33
GS4_Fiend
GS4_Fiend's Avatar
it would help alot of you got a scanner that shows fuel trims.
Old 03-11-13, 05:19 PM
  #34
canucklehe
canucklehe's Avatar
these 92 93 models are OBDI, would that make a difference?
Old 03-13-13, 06:28 AM
  #35
StuckInVA
StuckInVA's Avatar
An easy way to check for any MAJOR CAT blockage is to simply make sure that an appropriate amount of exhaust is exiting from your tail pipe. If your exhaust is being being restricted severely you will build an excess of back pressure and it can cause your engine to run terribly. This happened on my buddies 98' Tracer; He never knew until the pressure blew apart the flange before the CAT (although it was in pretty rough shape to begin with). When he finally had it replaced it felt like he'd put a brand new motor in the car. The difference was really night and day.
Old 03-14-13, 01:13 PM
  #36
lexus4all
lexus4all's Avatar
I'll have the cat checked out next week. If it proves to be clogged, I might save up more cash so I can get both the new cat and a custom Y pipe. I've been informed that a wider Y pipe adds quite a bit of HP.
I was thinking of doing the porting while my heads were off, but I was quoted $800 and I simply didn't have the cash at the time. Could have done it myself, but I don't have a garage to keep this car in so....ohhh well.
Old 08-24-14, 10:50 AM
  #37
austin3vzf
austin3vzf's Avatar
i have a 1992 lexus es 300 with the 3vzfe 5 speed trans and im did the vc gaskets intake gasket cleaned the intake and changed plugs and wires now im changing the clutch.... its seems like i would have to drop the down pipes? im not sure i have everything reaady to pull the trans but the bottom three bolts i think need to be removed but i cant with the pipes in the way.. anyways anybody have any experiance with doing a clutch in one of these it is my first time any pointers would be awsome thanks!
Old 08-25-14, 08:57 AM
  #38
canucklehe
canucklehe's Avatar
never had a standard, but the "Y" pipe is pretty easy to remove. I seem to recall a couple of springs to pull off near manifolds, and maybe a clamp or 2 down below, then it's loose/disconnected, some wiggling and twisting and it's off and out of the way.
Old 08-25-14, 08:18 PM
  #39
austin3vzf
austin3vzf's Avatar
Igot everything out and it's all ready for a new clutch but I can't find a new flywheel anywhere no parts stores and not even online they are all the wrong ones and the ones that would work are aftermarket and expensive youhave any ideas I was thinking getting it machined but because the wholefriction side of flywheel is even eighths non friction part so wouldn't that make the clutch stretch more or have less room to grip?
Old 08-25-14, 10:04 PM
  #40
Received 2,677 Likes on 2,267 Posts
Search for part number 13405-62020 this was used on quite a few cars including the Solara. If your flywheel can be resurfaced the shop doing it will look up the specs to see if there is enough material left.
Old 08-28-14, 06:35 PM
  #41
dlamb89
dlamb89's Avatar
Check the Throttle position sensor
Posted from ClubLexus.com App for Android
AirCapital
12
04-11-16 05:44 AM
Brn2fish
02-24-16 04:44 AM
PDXLex
27
11-13-12 06:54 AM
LexusDaisy
16
08-06-05 11:10 AM
equick
02-04-03 04:37 PM
Quick Reply: 1992 ES300 Acceleration Issues
