2000 ES300 Won't start after battery swap
Old 01-06-13, 02:36 PM
namklak
namklak's Avatar
Default 2000 ES300 Won't start after battery swap
Five year old battery died at wife's work parking lot. Installed new battery in cold and dark without cleaning terminal clamps. Car started off new battery and drove home. Car sat for two days, then I removed and cleaned the clamps, then re-attached the clamps. Now engine turns very fast but won't start. No kicking of engine, feels like no gas or no spark. I don't smell any gas.
Should I check fuses - which fuses and where are they located?
Do I need to somehow reset the ECU?
WTF?
I understand general internal combustion technology in theory, but I am a terrible mechanic.
Please, thank you, etc.
-Bob
Old 01-06-13, 03:23 PM
namklak
namklak's Avatar
Found two fuse boxes in engine compartment by battery - all fuses look and ohm okay. Crap.
Old 01-07-13, 05:46 PM
hzt30
hzt30's Avatar
If engine turns fast, as if it is free wheeling, then this could be a broken timing belt. Check that and go from there.
Old 01-14-13, 09:47 AM
namklak
namklak's Avatar
Default Blown ECU
So apparently , while cleaning the battery cables, I blew the ECU. I pulled the neg first, and re-attached the neg last, so ??? Maybe I did some sort of "contact-bounce" or something. Mechanic found some used ECU on 'net for $375. Never had that problem before while changing a battery. This ES300 has been a pain - multiple sets of ignition coils, bad oxygen sensors, CEL causes tranny to not shift into OD (that caused numerous head aches), always pulls slightly to the right (not my only FWD, I know what torque steer feel like). This is by far the worst Toy I've ever owned. I wish I could afford a car payment right now...
Parsa
03-03-16 04:09 PM
pirate2050
01-19-14 11:15 AM
tmf2004
06-19-09 06:37 PM
CPerez100
02-11-03 04:21 PM
Quick Reply: 2000 ES300 Won't start after battery swap
