Why Gas Mileage is SO bad?
Old 12-21-12, 10:27 AM
GaryZhao
GaryZhao's Avatar
Default Why Gas Mileage is SO bad?
Hello,
Wonder if anyone can share your experience & knowledge for my issue -
My 2005 ES330's fuel cunsumption is about 12-14 mpg, which is really bad. I tried everything I could such as cleaning MAF sensor, replacing air filter, adding engine cleaner addtive. Unfortunately nothing is improved.
In addtion, I don't think gas tank leaks becasue I never smell gas when it parks in garage. However, I do smell gas from muffler pipe when the car is started.
Thanks in advance for your help!
Gary
Old 12-21-12, 11:07 AM
GaryZhao
GaryZhao's Avatar
Extra information: The car does give me 400+ per tank if pure highway driving, that means it has 22 to 23 mpg for highway driving.
Old 12-21-12, 01:03 PM
BDSL
BDSL's Avatar
When you fill up, how many liters of gas did you put in?
Old 12-21-12, 01:35 PM
mitmaks
mitmaks's Avatar
any check engine codes?
Old 12-21-12, 04:04 PM
Hayk
Hayk's Avatar
Fuel economy is a trick subject. It depends a lot on driving habits. Do you mostly drive in rural areas and/or a city? How aggressive are you with acceleration and braking?
One other thing to check is your tire pressure and alignment, but those have to be really bad to affect your MPG.
Old 12-21-12, 05:07 PM
toytrain13
toytrain13's Avatar
I went on a 1600-mile trip recently, with my wife, in our 2002 ES300. I realize that this car has a smaller displacement engine than yours, but nevertheless, door-to-door, our mileage on the computer was 30.0 mpg (90% Freeway, Premium). Since I always note gasoline quantity and odometer reading when I fill up, I was able to calculate the mileage again, at 30.0 mpg. Not too bad!
Old 12-21-12, 05:33 PM
GaryZhao
GaryZhao's Avatar
No engine code, as I don't see any problem except bad gas mileage.
Old 12-21-12, 05:35 PM
GaryZhao
GaryZhao's Avatar
I manually calculated it a few times.
Old 12-21-12, 05:37 PM
GaryZhao
GaryZhao's Avatar
Generally I am not an aggressive driver.
Half highway and half city.
Old 12-21-12, 09:00 PM
MrShim78
MrShim78's Avatar
you should get a obd/datalogger device OR obd scanner like an elm 327 and then use obd software and datalog a few trips.
they will tell you whats going on your fuel consumption, fuel trim,etc. thats probably a better way to determine whats going on if you have tried out all the basics and like Mr Booby said you have no alignment issues.
it could be, and i am just guessing randomly, that your o2 sensors or cat converter is bad? not bad enough for a check engine light but bad enough to throw off some readings and make the engine run rich.
Old 12-24-12, 06:06 PM
GaryZhao
GaryZhao's Avatar
Thank you Shim, your analysis makes some sense to me. I would try it. Any update will be posted.
Gary
Old 12-26-12, 07:11 AM
285exp
285exp's Avatar
Hello,
Gary
If it's getting 400+ miles on the hiway, then it's getting 26-27 mpg hiway, which is about right. Has the car always been getting 12-14 combined, or is this a recent change?
Old 12-26-12, 11:59 AM
BostonVP
BostonVP's Avatar
this could be a shot out of the blue, sounds faily simple, but are you using premium gas?
Old 12-26-12, 12:23 PM
285exp
285exp's Avatar
Premium gas is not going to have a noticeable effect on his problem. I have an 04 ES330, and have used both, there is no measureable difference on mpg.
Old 12-26-12, 12:28 PM
BostonVP
BostonVP's Avatar
Isnt a 2004 es330 a 6 cylinder? For some odds reason right, on my 99 es300 if i was to put in 10 dollar worth of regular gas, it would last me for about an 1 hr of driving, compare to if i use premium, it lasts me twice as long.
Quick Reply: Why Gas Mileage is SO bad?
